cb installed....good so far.
Old Sep 21, 2012 | 03:10 PM
Kojack's Avatar
Default cb installed....good so far.
I finished my cb install today. Got an swr of 1.2. Sounds good to me..
Old Sep 21, 2012 | 09:29 PM
arjeeper's Avatar
Have you been able to hear anything? Tune to 17 and 19 and see if you can copy anyone. Ask for a radio check and see if your transmit is working too.
Old Sep 22, 2012 | 07:11 AM
lolpetewtf's Avatar
I live 20 minutes from Boston and I hardly get anything.
Old Sep 22, 2012 | 12:20 PM
Kojack's Avatar
My buddy and I did almost 400kms today of road. Cb worked great got over 5km between us and could still hear each other good. Good enough for what I need. Only odd noise is when I run my hid hellas. Just squelch it out a bit.
Old Sep 22, 2012 | 04:44 PM
arjeeper's Avatar
Sounds all good!
Plenty of electronic items cause RF interference. I wouldn't worry about it too much unless it inhibits communication.
Old Sep 23, 2012 | 02:44 AM
Kojack's Avatar
Sounds all good!
It probably will at the extents of distance between us. But I don't see a problem in closer ranges like on or two km.
I'm going to try a 4ft whip as well to see the difference in distance available for communication.
Old Sep 23, 2012 | 11:00 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
There might be a little change in the distance.
Just remember after you change the whip, to recheck the SWR with the new antenna.
Old Sep 25, 2012 | 01:06 AM
Kojack's Avatar
yes, for sure. Its working really good. From reading on here I was expecting really crappy performance. But it worked fine. 110% pleased. And for a full antenna setup for 40 bucks including coax, that's a killer deal.
Old Sep 25, 2012 | 03:17 AM
arjeeper's Avatar
It's all about expectations. A mediocre antenna may be perfect for your needs as long as you have reasonable expectations.
For VHF duties in my Jeep, I run just an "ok" antenna, understanding that I'll likely never try to work simplex and than the reduced size is more important than maximum antenna gain.
Old Sep 25, 2012 | 04:32 AM
Kojack's Avatar
VHF duties is a different ball of wax!
For CB, I don't think it matters as much!
