cb installed....good so far.
Originally Posted by arjeeper
Have you been able to hear anything? Tune to 17 and 19 and see if you can copy anyone. Ask for a radio check and see if your transmit is working too.
Originally Posted by Kojack
My buddy and I did almost 400kms today of road. Cb worked great got over 5km between us and could still hear each other good. Good enough for what I need. Only odd noise is when I run my hid hellas. Just squelch it out a bit.
Plenty of electronic items cause RF interference. I wouldn't worry about it too much unless it inhibits communication.
Sounds all good!
I'm going to try a 4ft whip as well to see the difference in distance available for communication.
Originally Posted by donnie
There might be a little change in the distance.
Just remember after you change the whip, to recheck the SWR with the new antenna.
yes, for sure. Its working really good. From reading on here I was expecting really crappy performance. But it worked fine. 110% pleased. And for a full antenna setup for 40 bucks including coax, that's a killer deal.
For VHF duties in my Jeep, I run just an "ok" antenna, understanding that I'll likely never try to work simplex and than the reduced size is more important than maximum antenna gain.
