CB Mount, lets see yours
Old Nov 6, 2010 | 02:54 PM
  #21
Ride_My_Jeep's Avatar
Originally Posted by feroxjb
Voila!
Attachment 100425Attachment 100426Attachment 100427
Gotta have my junk tray!!
And of course it locks..!
I like that, but I tried that already and the raido is just a tad too big
I switched the radio over to the driver side and used the bolt already on the side console...I am a big guy so that radio limits my leg movement somewhat...A temporary fix...I believe eventually it will be mounted on the rear of the console..Probably my best option for the 2 Dr
Old Nov 6, 2010 | 07:05 PM
  #22
tslewisz's Avatar
Originally Posted by althekiller
That bracket looks pretty nice, you made that yourself?
Thanks! Yeah, I made it out of a chunk of the end of the OEM front bumper after I stubbied it.
Old Nov 6, 2010 | 08:25 PM
  #23
heres a pic of where mine currently is
Old Nov 7, 2010 | 11:05 AM
  #24
dsrtlvr50's Avatar
Hey everyone, newbie here. First time posting. Thought I'd give it a try! I have a uniden 520xl I mounted above the mirror. It's out of the way and looks good. I added a plug behind the radio so I can remove it when I need to. I made a flat bracket out of aluminum to mount to the overhead plastic piece, then mounted the radio bracket to it. I left just enough room between the radio and winshield for the antena cable and wires.
Old Nov 16, 2010 | 12:32 PM
  #25
yayomtz's Avatar
Default how....
Voila!
and how can i wired ?
Old Nov 16, 2010 | 01:30 PM
  #26
jennekin's Avatar
Default Thanks for all the great replies
So I ended up mounting mine above the rearview mirror. I thought twice about running the screws through the plastic, but finally just did it and glad I did. It works great. I also bought a magnetic antenna from Radio Shack, ripped it apart and mounted it through my license plate holder to hide the wires. Looks pretty sharp. I will post some pics tonight.
Thanks for all of the great ideas.
Cheers
Old Nov 23, 2010 | 01:53 PM
  #27
azrwilkinson's Avatar
Here is my new Pro 520 XL and custom stainless steel antenna mount.
Old Nov 26, 2010 | 07:16 AM
  #28
Willybugman's Avatar
Mounted mine inside the console. Ran and external speaker and mounted it in the knee blocker lower pop off panel. I used an amplified speaker I bought from Passport that is used on the 9500CI. When you close the console the mic wire comes out the side nicely and the speaker is plenty loud and clear. Out of sight and works fine for me. The install is a little timely but turns out clean.Attachment 105008
Old Dec 8, 2010 | 08:25 PM
  #29
genesbro's Avatar
bump ...........
Old Dec 8, 2010 | 08:58 PM
  #30
Sapper12b's Avatar
Here is mine ... using the new 50th Aniv Cobra
ID:	108277   Click image for larger version
ID:	108278   Click image for larger version
