CB Mount Location
Old May 7, 2007 | 09:58 AM
BARNO's Avatar
Default CB Mount Location
Has anyone mounted their CB above their radio on/above the dash? I'm considering mounting mine there. Looking for some ideas and pics.
Thanks.
Old May 7, 2007 | 12:02 PM
TrAvELAr's Avatar
I saw someone had done it... I can't seem to find the thread now.
Old May 7, 2007 | 01:29 PM
ClownBaby's Avatar
yeah you can do that
you have to drill it though....do you mind drilling the plastic cover??
Old May 7, 2007 | 04:04 PM
zoomzoomjr's Avatar
Default Mount
I am working on a mout for above the radio. I am using Hooked's idea, and modifying it (for the electronics mount). Hopefully I'll finish tomorrow and post it.
Old May 8, 2007 | 05:01 AM
BARNO's Avatar
I don't mind drilling through the plastic. I went to the dealership and bought a new cover piece for just over $5 - just in case I screw up.
I'm also going to dream something up and eventually post it.
Old May 8, 2007 | 09:22 PM
Sixgunz's Avatar
I mounted my CB above the radio, it works great. I wired all of the wiring down into the dash behind the CB & it looks clean...you can't see any wiring. I even wired a PA speaker & remote speaker to it.
The only consideration you need to think about is that if you have a Rubicon (or a unit with an electronic compass) you'll need to remove the speaker from inside your CB.
Most CB's have the speaker on the bottom...well, as I learned the hard way...the magnet on the speaker throws off the JK's compass unit, which is mounted against the top of the plastic cover over the stereo. Basically, it's too close to the speaker magnet & I am assuming it's a magnetic compass.
So, I took out the CB speaker, mounted a remote speaker in front of the transfer case shifter, & it works like a champ. The compass is back to normal as well.
Old May 9, 2007 | 04:48 AM
JackMac4's Avatar
That's odd...aren't most CB speakers shielded? Guess not....never even occured to me. Thanks for bringing it up.
Old May 9, 2007 | 06:27 AM
BARNO's Avatar
I mounted my CB above the radio, it works great. .
Do you have any pics Sixgunz?
Old May 9, 2007 | 07:31 AM
FiveOff's Avatar
Old May 9, 2007 | 10:20 AM
Sixgunz's Avatar
Pics? Sure! How do I post them??
