CB Radio kit?
Anyone have this kit?
http://www.quadratec.com/products/96080_11.htm
I talked to one other guy on the forum and he said it looks to be good but just curious if anyone actualy runs this set up now. Thanks!
The antenna mount is good, but when I upgraded to a Mopar Bumper/tirecarrier, the mount no longer worked with the 3rd brake light so I switched to a Teraflex mount (same idea just on the otherside of the tire carrie/third brake light.
The antenna is a good one, but I was worried about the tall antenna getting snapped off in the woods, so I went with a 2 foot antenna.
That's the kit I first bought. The only thing I'm still using is the coax cable. The radio is a good radio, the mount is solid, BUT you can't move the seat up all the way anymore, so cleaning became a pain. I ended up switching to a Cobra 75wx.
I purchased this kit from rightchannelradio.com . I had no problems with installation and used for an entire weekend with no problems.Attachment 244118
I used that radio as a back up in my 18 wheeler. When I retired I sold it to another driver as his only radio. 13 years later, it is still going strong.
A friend bought that kit. He was happy. It is a good set up.
Could I fit in my garage with the antenna you think? and what do you mean you you can't move the seat up? I am going to go with the mount by the driver side leg. And I am prolly just going to end up taking this someplace to get installed because i have no clue what I am doing and don't want to screw it up. Glad to hear its a good radio! hows the range? I am mostly using it for trails but I may turn it on here and there on the highway just to see whats going on
The seat will only slide as far front as the radio is mounted. You are mounting it to the plastic console so I waws worried about breaking the console every time I moved the seat forward.
Install is a breeze. The hardest part is running the coax through the tail gate and the power wires through the fire wall, and a 10 year old can do either.
Originally Posted by Cold
I have this kit and I LOVE IT! I mounted the CB above the mirror. The cable is a perfect fit when You run it in the roll bar padding.
