Cobra 75WX - Be careful of hot spot behind trim
Old Apr 27, 2009 | 05:09 AM
Machine154's Avatar
Default Cobra 75WX - Be careful of hot spot behind trim
I thought I found a nice place to tuck my Cobra 75WX cable after mounting the remote unit under the glove box. Where the trim piece below the glove box meets the center panel trim, there is a nice little nook that you can put the connector and cable. BUT, as I found out this morning when trying to disconnect it, that there is something VERY HOT behind that panel. I pulled my hand back pretty quick. I don't know what the component is behind there, but it is pretty freakin hot. No damage to the cable though. I think the connector was against the hot metal.
Old Apr 27, 2009 | 05:13 AM
bOLsAK=3's Avatar
Heh?! Thanks for the heads-up!
Old Apr 27, 2009 | 05:26 AM
Trail Bud's Avatar
it's part of the heater core.
Old Apr 27, 2009 | 05:42 AM
Machine154's Avatar
Originally Posted by .:eMETAL:.
hmmmm... any pics? you're not talking about the piece directly under the glove box are you? if so i have mine mounted under the glove box with the port coming out from there and never noticed this at all. unless you are talking about the side panel on the center console?
bad ground maybe? crossed wires with cig lighter? heater core?
how do you have it wired?
edit:
Here is where I ran the cable. It looked very nice with the cable tucked behind there and only the cord without connector coming out.
Old Apr 28, 2009 | 08:51 AM
Can't see the pic here at work but radio signals can create heat.
Old Apr 28, 2009 | 10:09 AM
HappyCurmudgeon's Avatar
Eternal ***erator
No, it isnt radio signal/electrically generated heat, it's heater core/ac physical piping. and it is hot enough to burn you, easily.
I know what the OP is refering to, i'll try to find a pic to describe it.
(if anyone knows of one, please post it up)
Old Apr 28, 2009 | 10:18 AM
Eternal ***erator
See the silver pipes top center running to lower left? DONT TOUCH!
*danger will robinson*
.................................................. ...............these ones...|
Pic borrowed from HG97TJ
Old Apr 28, 2009 | 10:58 AM
RDY4RKS's Avatar
Thanks for the info. Was planning to mount mine in pretty much the same location. Guess I will have to be a little more careful than normal when I do.
Old Apr 28, 2009 | 11:23 AM
Eternal ***erator
i have mine mounted pretty much exacltly like that pic, its fine, just becareful with your fingers so you dont burn yourself while mounting it. after its mounted there is no problems with mine at all.
Old Apr 28, 2009 | 05:51 PM
jmc's Avatar
jmc
Thanks for the tip, I just got mine in the mail today. Only had time to get the antennae mount on and the wires run inside.
