Cobra 75WXST Mounting
Old Apr 13, 2009 | 07:39 AM
kcnal's Avatar
Default Cobra 75WXST Mounting
Hello all!
I just purchased the 75WXST. I've spent a number of hours looking through the posts on mounting options without drilling through the dash, etc. and have found a couple.
Any suggestions for any mounts that I may have not caught that is convenient and looks good?
Old Apr 13, 2009 | 12:15 PM
kcnal's Avatar
Which panel are you talking about..the one with the Mic connectors (passenger lower floor) or where the Mic is mounted on the lower picture?
I ran across your post when researching before but couldn't find it again....thanks for the post/reply.
What is (and where did it come from) the attachment you have for the mic in the lower picture?
Old Apr 13, 2009 | 05:02 PM
dburgette's Avatar
Here's mine with a cut end of a coat hanger wrapped around the header above the rearview mirror.
And the finished product looks like this:
By the way, you can't see the hanger once the handset is in place.
Old Apr 13, 2009 | 09:19 PM
RedRockJk4x4's Avatar
I found it at Mopar Parts America for $29.00 but im sure you can get it cheaper than that. Its just called a lower panel and is under the instrument panel category.
Old Apr 14, 2009 | 09:58 AM
Mark Doiron's Avatar
I went to a local truck stop and bought a bent wire loop that attaches to the button on the back of the mic unit, then has another hook that hangs neatly from the footman loop above the rear view mirror. Cost $3. Here are a whole bunch of similar options:
h t t p://www.thefind.com/instruments/info-cb-microphone-hanger
Old Apr 14, 2009 | 10:50 AM
wildandwillin's Avatar
I bought the LL Cool Tech works nicely
Old Apr 15, 2009 | 06:27 AM
HG07JKRubi's Avatar
Click the Cobra 75 link in my sig for my install. You could always run the quick disconnect along the floor if you don't want to drill the lower panel.
Old Apr 16, 2009 | 06:52 PM
artpics's Avatar
Originally Posted by HG97TJ
C You could always run the quick disconnect along the floor if you don't want to drill the lower panel.
this is how i have had mine for the last 12 months
Old Apr 16, 2009 | 08:21 PM
kcnal's Avatar
Default Thanks...
Thanks to everyone for their posts and pictures. It really helped. I like a lot of them. I'm really looking into Toad/Bullfrogs solution. I think it will fit the bill, although there were some really great looking installs you guys posted!
Thanks again.
