In-Dash CB install
Old 12-05-2010, 10:44 AM
Frog's Avatar
Originally Posted by NorthGAX
I installed both in the space of the OEM radio.
I was only able to find one CB that is 1 DIN in size (the Cobra 18WX). I ordered the new head unit and a double DIN dash trim from Crutchfield. The mounting was straight forward but you will need to remove the dash bar (the same piece the double DIN radio install state).
Would you say that the space in the dash was pretty much full when you put these two in? I have a Uniden PC68LTW CB that I want to install w/a single din cd player and am trying to figure out if they will fit together. The dimensions of my CB are 12.8 x 11.2 x 3 inches ; 5 pounds. Any idea if this would work?
Old 12-07-2010, 11:47 AM
Heavy_D's Avatar
Great looking install. I wanted to go with a double DIN NAV unit but after seeing this might go with the single DIN with flip out monitor instead so that I can mount my CB in the dash.
Originally Posted by DKJeep17
Did you just by a regular Double DIN mount? Cause when searching for the jeep it pulls up a single DIN, but there are Double DIN's for other vehicles... which one did you find that mounted well?
Thanks!
It only shows single DIN because in order to mount a double DIN, you have to cut a piece out of the metal dash support because your typical aftermarket stereo is deeper than the factory unit. There is a good write-up on here someplace. If you need a link, I can find it for you later.
Old 12-07-2010, 12:18 PM
Mookie's Avatar
Real nice setup... I was also thinking of doing a double din nav unit, but I'll have to reconsider. Thanks for the post!
Old 12-18-2010, 02:28 PM
gadget799's Avatar
This set up was way to sweet to pass up so i did my own thanks for the idea NorthGAX
Kenwood KIV-BT900 + Cobra 18 WX ST
Attachment 110422Click image for larger version
Name:	New Stereo+CB Install 1.JPG
ID:	112621Click image for larger version
Name:	Stereo+CB Install 2.JPG
Old 12-24-2010, 05:39 PM
robo_tn's Avatar
this is the best set up i have seen!!
if i didnt have the mygig i would do this, that is awesome!
Old 12-24-2010, 06:09 PM
peanut's Avatar
Yep , great Idea I did it today Thanks
Old 12-24-2010, 06:11 PM
JC4me's Avatar
Any heat issues with this set-up??
Old 12-24-2010, 06:22 PM
gadget799's Avatar
None so far but that is partly why i opted to go with a media deck with no cd rom they produce almost no heat (no moving parts)
Old 12-25-2010, 07:42 PM
mdnky's Avatar
The DIN size (single) is 7" x 2". The Cobra 18 is 1.88" according to their specs.
Old 12-26-2010, 08:31 AM
Frog's Avatar
Thank you
Quick Reply: In-Dash CB install
