Got the CB installed
Old Aug 28, 2013 | 03:01 PM
Bonedoc's Avatar
Interesting to know and read. I have very little experience with CB's. My fiance just bought me Cooltech's all in one package with the license plate holder mount and a 4ft firestik for my birthday. Hoping to get it installed this weekend. I'm going to have to request help on how to tune it. Hope yours works out, curious to know to see what issues I may run into.
Old Aug 29, 2013 | 07:04 AM
firecapt's Avatar
Originally Posted by BlackRockBurner
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=492848"/>
I did a bit of internal brace trimming using a flexible extension on a Dremel with a cutoff wheel. I was able to get the base of the antenna high on the tub. My SWR is 1.2 across all channels with the hardtop. I have a 3' Firefly.
Did you unscrew the tuning tip then back it in a few threads? Make sure to replace the rubber tip when taking the reading too.
When mounting the mount, did you clear the paint( grind to bear metal) where the reinforcing back plate makes contact with the inside, making that a ground point?
Old Aug 29, 2013 | 10:48 AM
BlackRockBurner's Avatar
I ran a 6" ground strap to a 1/2"bolt I drilled into the tub. Used star washers to bite into the metal. I thought of clearing the paint behind the rear fender but to make good contact, the surface area would have to be 1"x3" or the area of the M2 mount back plate.
Old Aug 29, 2013 | 11:53 AM
zstairlessone's Avatar
Originally Posted by bfdfreddie
Thanks for the post.
What brand did you get? I like the size. What in your eyes were your other options to mount it? Also does anyone know if I get rid of my radio antenna will I lose only radio am/Fm? Since I never really listen to radio anymore. Thinking of mounting CB antenna there is why I ask.
If you do let us know. I've been looking at putting the antenna there too. Got my CB, haven't installed it yet cause everything I read about how bad mounting them between the tire and body is.
Old Aug 29, 2013 | 03:54 PM
firecapt's Avatar
Well my original antenna was not one of the Firestiks with a tunable tip. After speaking with a tech at Firestik he felt that the 3 ft antenna I was running would have worked if it had a tunable tip. He felt based on his experience that being on a Jeep, the best I could hope for would be in the swr 2 range and distance would still be an issue, but would be fine for trail purpose, if it were a tunable tip. I ordered a 4 ft firefly(very light weight) with a tunable tip. I also ordered a heavy duty 3inch spring. Well now instead of 6 inches above the roof, I have 21. The SWR, using the tunable tip, tuned to 1.5, channel 1 thru 40. I believe for those not looking this much antenna above the roof, a 3ft firefly w/tunable tip and a 3 inch spring would be perfect. The techs at firefly were awesome , helpful and patient. Hats off the good customer service. As mention in an earlier post, I did not have to grind paint off to bear metal behind the support plate of the mount.
I did run a heavy ground wire as mentioned by "BlackRockBurner" as an extra ground. Thanks for all the good advice!
Old Aug 30, 2013 | 07:21 PM
cmcraig's Avatar
Installed the CB today. Tomorrow I'll go to an open area and hook an swr meter up. Happy with the mount. Check it out!
Compact CB in the console
Attachment 492111
Side mount antenna on rear.
Attachment 492112
Slick install. I have a similarly sized radio I was thinking of mounting the same. Your pics have just pushed me to do it tomorrow. Thanks!
And on a side note.............where did you get the decal on your back window in the 2nd pic?
Old Aug 31, 2013 | 03:26 AM
firecapt's Avatar
I got it from "runyoustickbastards.com.. But it appears he may have gone out of business. But just type in "run you stick bastarsds" and a lot of others have came up with similar designs.
Old Aug 31, 2013 | 05:16 AM
mbanik's Avatar
I think you will be good to go with a 4' tuneable. My current SWR readings:
Ch 1 - 1.8
Ch 19 - 1.2
Ch 40 - 1.6
I need to play with it a bit more and hopefully bring 1&40 in a little bit.
Old Aug 31, 2013 | 05:27 AM
tribulation138's Avatar
Is it weird that I only have a scanner in the jeep? Not cb.
