Handheld CB recommended???
Old Dec 9, 2009 | 08:48 AM
JulianK's Avatar
I use the Midland handheld radio. It also converts to attach an external antenna which you can mount using a quick release.
Old Dec 9, 2009 | 09:10 AM
jkrubi09's Avatar
Thanks for all the help. Im liking the Cobra 75. It looks pretty good and would suit my needs I believe.
Old Dec 9, 2009 | 07:08 PM
w squared's Avatar
Originally Posted by nealxam
Not hand held, but I highly recommend the Cobra 75 WX-ST.
Nothing to steal or mess with when you're not wheeling and a good CB when you need it.
I can hear folks great on mine and they say they can hear me great too.
If I remember correctly, you're gonna need the CB, a Bullfrog or Cooltech VersaMount mic mount (or stick it in your cup holder when not using it) 18' coax cable, an antenna mount, and an antenna.
There's a great write up on here on how to install it.
It's been a long time since I put mine in, but you'll probably have about 175.00 in the whole set up and you'll have a good CB for off road use.
As for the antenna, just get a TeraFlex tailgate mount and one of these and you're in business. I
This is made by Firestik, but I'm sure any brand would work.
I ONLY install my CB and antenna when I'm going offroading.
I know it's not what you posted about, but I do hope you'll consider going this route. I've never heard of anybody that's unhappy with it.
This is sounds advice. I went to a shop that only sells CB's, and talked to a guy who is an actual expert...and I ended up with essentially the same setup.
You can easily mount the antenna on your tailgate or license plate bracket, and use a quick-detach to take it off when you're concerned about overhead clearance.
If you were to go with a handheld as your main CB, I think that you would quickly become frustrated with the overall performance. CB operates in the 11 meter band, and that means that teeny little rubber duck antennas just don't work all that well.
Old Dec 9, 2009 | 07:15 PM
jkrubi09's Avatar
Yep I'm going with the Cobra 75 set up. Thanks for all the info. Now I just have to wait until Christmas to get it since the wife says its for Christmas. Oh well I've spent enough this year on this rig. A few more weeks of waitin aint gonna hurt!!
Thanks guys!!
Old Dec 9, 2009 | 07:46 PM
Excellent Choice with the Cobra 75, I drilled the aftermarket (driverside) mirror mount and ran a 6' coax. If your worried about the length get a 24" antenna and it is flush with the top of the jeep off the mirror bracket.
Old Dec 10, 2009 | 06:42 AM
sin52's Avatar
Originally Posted by RedneckJeep
I have the Midland 75-822. It converts from a mobile to a hand held. Nice little deal.
X2 on the midland! It's nice to know I can disconnect it from the jeep antenna, jump out, act as a spotter(it comes with a battery pack and small ant), then jump back in and use it as a mounted cb. I was close to getting the motorola but liked the ability to use it unattached from the jeep. can use it wandering around the campsite listening for other guys to arrive for the weekend.
This pic is attached to wheel all day or for the highway
This is the setup if you're helping someone navigate a long run as a spotter or around basecamp.
New egg had 'em for $70ish.
The range is same as others with same antenna setup.
Old Dec 10, 2009 | 10:09 AM
wolfpuppies3's Avatar
Default This one works well for $99
Use it hand held with it's own rubber ducky antenna or mount the magnet mount 12" antenna on the hood in the center of the windshield.
Handheld Weather Alert CB Radio - $99.00
http://www.radioshack.com/product/in...ductId=2103702
Old Dec 10, 2009 | 02:17 PM
Mark Doiron's Avatar
I'm using the Cobra 75 and like it a lot. I just converted from a (busted) 3-foot antenna to a 2-foot and it just barely pokes above the rear of the top--about two inches max. It's mounted on a homemade bracket made from a straight piece of 1" aluminum bent at 90 degrees and painted--cost all of $8 for the metal at my local hardware store. I could have bent it even lower to lower the antenna height. The smaller antenna will reduce performance, but save the antenna on the trail, where mine got busted in the first place. I've used a handheld and it worked fine, but range is even more limited. Here's a pic of my bracket. It's just mounted to the bolts that hold the spare tire rack.
Old Dec 10, 2009 | 07:51 PM
w squared's Avatar
That's very similar to my setup, Mark.
I have a pair of the Cooltech mounts (one for CB, one for 2m/70cm) that bolt to the tire carrier. I particularily like them because they're made out of a chunk of 1/4" stainless bar stock - they'll probably outlast both the tailgat and the antennas
I actually run a 4 foot whip on there - but I chose a very flexible Wilson whip, and also added a quick-detach for parking garages and car washes.
Old Dec 11, 2009 | 08:57 AM
Fermin's Avatar
Midland 75 here too, but I don't use it as a hand-held I got mine for $30
