Handheld CB Users !!!
Old Jul 16, 2009 | 08:34 AM
ellsrya's Avatar
Default Handheld CB Users !!!
Here is a pretty clean way to gain full reception for your handheld cb but still keeping it clean and not to many wires
works great!
You will need
3 ft Antenna cable(black)
bnc to uhf connector
2" female to female unf connector
18' antenna cable
heat shrink tubing
chair leg cap
i find that the shrink tube is what keeps it clean looking
Let me know if you want more pics or info
NOTE: Use a 5/8 bit to drill through the black plastic and a 7/8 bit to go through the plastic underneath to allow room for your connection to go through
Finished product with chair leg cap and a piece of heat shrink around the nut
Same as above but with cap removed
Same as above but with wire attached
Very clean
Attached bnc connector to cable and heat shrink to clean it up
How i ran the cable from antenna
My mount with shrink tube again
Old Jul 16, 2009 | 08:55 AM
woodweavil's Avatar
thats great where do you get the 3ft cable to hook to the radio I cannot find one
Old Jul 16, 2009 | 10:15 AM
bkw's Avatar
bkw
Thats the same place where I have the plug for my Cobra 75WXST.
Thanks for the chair leg rubber cap idea!
Old Jul 16, 2009 | 01:38 PM
ellsrya's Avatar
www.radioworld.ca
is where you can find all the parts i used except for the chair leg rubbers
Old Jul 16, 2009 | 01:41 PM
JPTwinz's Avatar
Very nice.....what was the total cost?
Old Jul 16, 2009 | 06:09 PM
ellsrya's Avatar
$53 and i bought the CB radio for $50 off kijiji
Old Jul 16, 2009 | 07:54 PM
Chicken Corners's Avatar
So for an antenna you are using the short one that came with the CB?
Old Jul 17, 2009 | 06:16 AM
ellsrya's Avatar
no i bought a new 4ft antenna. from radioworld as well.
Old Jul 19, 2009 | 01:58 PM
Ryanc's Avatar
So is your reception as good as using a regular unit? Im assuming yes. This is a realy good idea.
Old Jul 21, 2009 | 05:41 PM
ellsrya's Avatar
yea no problems thus far!.
