install ???
Old Apr 16, 2012 | 05:58 PM
monkers's Avatar
Default install ???
I got an old cb given to me and would like to put it in for an upcoming ride. I dont know everything I will need, I will make the L shaped tailgate mount, but will need the antenna ( 3' Firestick) the cable to connect to the radio, what else will I need? Are the cables standard ? Any tips? Thanks
Old Apr 18, 2012 | 08:25 PM
Rooster76's Avatar
Have you seen these write ups, they might help?
Project-JK.com - Jeep JK Wrangler Resource » Affordable Jeep JK Wrangler CB Radio SolutionMidland Model-1001Z
Project-JK.com - Jeep JK Wrangler Resource » Cobra 29 LTD BT CB Radio Jeep JK Wrangler Installation Write-Up
I'm a noob myself but have been doing a ton of research on CB's. You can find Jeep/Off-road complete antenna kits if you do a web search.
I'm not sure what your thinking of with a L-Shaped mount. There are a few things to consider. Your best off putting your mount where the antenna won't be sandwiched between the spare and tail gate. I would try to fab something like the Arizona Rocky Road JK antenna mount that is higher up than the common teraflex one. A hood mount would give you better reception if your up to mounting in the front (preferably away from the FM antenna). It's best to have 1/3 of the antenna above the roof line. The higher the mount the better. The longer the antenna the better.
The antenna mount will need to have a stud mount. Click HERE to see what I'm talking about.
The antenna cable is PL-259. There is a more rare PL-258 that is used for dual antennas that you don't want. There is also options for getting a no-ground antenna (with about a 10%-15% decrease in performance). Those no ground units have there own special cable that you need to use.
Hope that info helps some.
Old Apr 19, 2012 | 02:17 AM
monkers's Avatar
thanks for the info, Im gonna check out the links, Im a complete newbie.....lol......lots to learn.....I only need it for short distance on the trails.....maybe if I get a quick disconnect I can use a longer antenna for better reception.....thanks for your help
