I hate guessing on bit size when using screws think i'll just bore and find bolt nut combo. At least then I can use it for more than holding just the mic. I think if they had one more bend on the end I could clip more things on with out worrying about sliding off with hard right turns
So drilled into my versamount. FYI if you have the versamount and have to drill do it before you mount it! Took a hunk out of one of the dash panels. Not to happy.
Originally Posted by Dayman
(Post 2950372)
i'm wimping out and gonna try the route of the handheld midland cb with a decent firestick antenna only looking to keep in touch with other people in my group... matthew |
The cb is a cobra 75 which is a handheld the mount is the mic mount cootech versamoun (not so impressed). Love the cooltech ultramount, quality stainless and didn't even have to run a ground for solid swr. love the cb you can't see it when I disconnect, didn't drill additional holes the mic hook up is long enough to just run under dash panels.
