Little Tarheel II and ICOM IC-706 MKii in 2010 JK
Old Aug 8, 2011 | 07:01 AM
goldtr8's Avatar
Originally Posted by JK-jeepit
Nice...
I'm actually interested in this also...
My Jeep gets mad at me at 60-70W...
I did not know a better way to say it, mine got mad, lifted its leg by, disconnecting the sway bar, messed up the throttle, had a miss and disconnected from the yaw controller ecu.
Good thing I knew my jeep is a male.
The fix was lots of bonding and a external choke on the coax for the common mode. There is a post somewhere in the forum, but I cant find it right now. I can transmit full power 100w on all HF bands. It took lots of work to get there.
Old Aug 8, 2011 | 07:05 AM
goldtr8's Avatar
Originally Posted by kd4ao
1. The radio is in its mounting bracket so it is about 1.5 inches above the floor, still this is something I need to watch,
2. I have only had a few short QSOs but so far no problem. I do like to park and operate with engine off though.
3. Good idea, I am trying to figure a way to attach a bonding strap or ? to the mount, any ideas?
4. Fun is what it is about, I haven't had a mobile HF rig since 1970 when I had my SWAN 350 in a Chrysler and a hustler on the rear bumper. I was so thrilled when I was able to work DX from I-5 in Washington, Oregon and California. Daytime 15 meters to Australia and the far east while driving was pretty exciting.
Since then just about everytime I tried HF mobile was a disaster so I gave in to VHF. But now thanks to availability of torroids things look a little better.
Search the forum for a post of mine that explains all the work I did to make HF not a disaster. (right now I cant find it) Other than the pics of your mount I am not familiar with it, so I don't have a good idea on how to bond it.
Old Aug 8, 2011 | 10:05 AM
Vernnz's Avatar
https://www.jk-forum.com/forums/show...hlight=esp+bas
Here is the post by goldtr8. It describes my version of "How did the Jeep get mad?"
Enjoy.
Old Nov 25, 2011 | 06:42 PM
Jpexpo's Avatar
I installed my IC-706 MKii and a Litttle Tarheel II in my 10 JK, using a Turbo Tuner and a Diamond K400 3/8C mount just below the top hinge on the gate. I have a few torroids on the coax, the motor control and a torroid on the power cable which is direct fed from the battery both pos and neg. It seems to be working pretty good so far, but I plan to do some bonding as required.
Bob
How has this mount held up offroad? Thanks for pics of you install this almost a duplicate of what I am thinking of running when I get my general.
Old Apr 11, 2012 | 05:50 PM
Sahara_Maverick's Avatar
Pulling this one from the catacombs... :-)
Anyone using a Hustler 1000 antenna? How does it work?
Does the 706 have an internal tuner like the 703 does or is it better to use an external one?
I'm considering a used 706 MKIIG. The 7000 looks great but too much money.
Old Apr 12, 2012 | 06:55 PM
arjeeper's Avatar
The 706 does not have an internal tuner. You might be better with a tuner at the antenna base anyway for a non-resonant mobile whip. Depends on your antenna choice.
Old Apr 12, 2012 | 10:52 PM
Thanks! I saw the Hustlers and those coils will not mix well with branches on the trails. :-)
How does the LT hold?
Icom sells one that pairs with the Icom tuner but that thing is way expensive. Any other good options?
Old Apr 14, 2012 | 05:26 AM
arjeeper's Avatar
The Icom whip and tuner are a bit overpriced. It's basically just a non-resonant whip. You could get most any wide range "remote" tuner and a 102" stainless whip for much of the same effect. Maybe trim the whip so it's resonant for 10m and let the tuner work on the other bands.
Old Apr 14, 2012 | 05:34 AM
arjeeper's Avatar
I installed my IC-706 MKii and a Litttle Tarheel II in my 10 JK, using a Turbo Tuner and a Diamond K400 3/8C mount just below the top hinge on the gate...
Great looking setup. I have a 706 I plan to instal in my JK as well. Giving me some good ideas here. I'm also considering a position under the drivers seat for the rig. Already have the remote kit for it.
Probably do a mount near the cowl for 2m/70cm, but I'm just not sure what I'll do for HF yet. I don't anticipate it being a tremendous performer. I'll probably just grab a few hamsticks to take with me when I go camping and stuff, but I at least need to find a good mount location. Yours looks quite clean!
73 de K5PO
Old Apr 15, 2012 | 01:28 PM
I found a MKIIG that seems in great condition. Now need to get to the tuner and antenna.
What remote tuners should I take a look at?
I have a manual screwdriver antenna used with the 703, but it's not suitable for mobile use unless I am parked. So, will also look at the LT. kd4ao's setup looks great indeed.
