Looking for a decent CB install in a 2011
Old Feb 9, 2011 | 10:51 AM
bstpierre's Avatar
If you want to continue with the Cobra 75 and just need a way to mount the mic you can use the www.proclipusa.com Jeep mount. It is a right angle piece of plastic that bridges the top of the radio to the lip of the dash top bin. It then has a mounting surface that comes predrilled for their device mounts but you can drill any holes you need for the mic mount.
I have the mount for my 2009 (which is different than the 2011) that I use to mount my iPhone.
Old Feb 9, 2011 | 11:11 AM
J2010k's Avatar
I'm running a Midland 1001Z on a custom mount to the passenger side of the console. I used the existing factory screw hole which makes installation an removal easy. I'm using a 4' firefly adjustable tip antenna. I'm getting 1.1 SWR readings. This set up is working well for me.
Old Feb 9, 2011 | 09:04 PM
bfcerny's Avatar
Any pics? Just bought the same set up. Any pics of your antenna mount?
Old Feb 9, 2011 | 09:17 PM
SWRUBI's Avatar
What he said -- any pics?
Old Feb 10, 2011 | 05:02 AM
J2010k's Avatar
The antenna is on a quick disconnect an bracket I got from quadratec. It was a little expensive but worth it. I'm getting great range and even though I used the aux outlet for power, the setup is clean. No engine noise. I hope this helps !
ID:	125927   Click image for larger version
ID:	125928   Click image for larger version
Old Feb 12, 2011 | 12:45 PM
o|||||||o's Avatar
Still looking for some decent pics of an install with the new 2011 interior...
Old Feb 12, 2011 | 02:53 PM
ke5rto's Avatar
I didn't see anyone post it yet, but here is the link to the Cobra 75 Install thread:
https://www.jk-forum.com/forums/show...ighlight=cobra
73s,
Brian
