Military antenna
Old Apr 24, 2011 | 09:44 AM
  #31
rfrogman's Avatar
Here is the antenna in NVIS travel mode with my homebrew adapter
Old Apr 24, 2011 | 09:55 AM
  #32
AK4Dave's Avatar
OIC..... So then you don't really talk on the radio when you're running down the road...???
Edit: I just got done looking at the Hi-Q website. What kind of warranty does he provide? I looked all over and couldn't find anything.
Old Apr 24, 2011 | 06:18 PM
  #33
rfrogman's Avatar
Actually you can transmit with the antenna in that position. NVIS allows you to hit station close in the skip zone (approx. 150 miles). Its not perfect but doable.
I don't use warranties often so I didn't look. If the military is using it in place of standard issue its good enough for me. Eham gives it a good review.
Old Apr 25, 2011 | 05:47 PM
  #34
AK4Dave's Avatar
What Hi-Q are you thinking about getting...???
Old Apr 25, 2011 | 05:56 PM
  #35
goldtr8's Avatar
I have been using a military tie-down bracket with 550 cord. It puts a lot of stress on the bottom element. The HF version of shakespeare antennas are not as flexible as their VHF ones you normally see on the HUMVEEs. I just finished fabbing a NVIS adapter that allows me to cant it at 90 degrees or lock vertical when stopped. As much as I like it I am considering switching out with the Hi-Q (screwdiver). The Marine Corp is using them with similar military spring mounts. My Army buddies will give me hell be it will still have the military look I was going for.
Take another look at the scorpion before you get the Hi-Q. I spent a lot of time researching this item and I am glad I did before I made my purchase.
Old Apr 26, 2011 | 07:28 AM
  #36
rfrogman's Avatar
Their small one Hi-Q-2.5 RT-S I can make an adapter for my Shakespeare 4244 mount that will mate to the 3/8x24 fitting. I might homebrew the controller.
Old Apr 26, 2011 | 07:30 AM
  #37
rfrogman's Avatar
Can the scorpion be adapted to my mount? or would I have to start from scratch?
Old Apr 26, 2011 | 04:35 PM
  #38
goldtr8's Avatar
I custom built my mount, but its just a solid stud type of mount that you use.
I got the shorty and its just one awsome antenna.
Old Apr 27, 2011 | 04:59 AM
  #39
rfrogman's Avatar
Thank you, I will definitely take a look at it.
Old Aug 15, 2011 | 04:17 PM
  #40
JK09's Avatar
Yes it would work for a CB since it goes to 30MHz. CB's are in the 29MHz range.
I was thinking CB was @ 10MHz?
