My Cobra 75 CB and antenna install
Old Jan 25, 2009 | 11:21 AM
  #191
JK-Rubi's Avatar
Originally Posted by m(a)ce
thanks for the input/info.
I did a search for coax & soldering and only yielded text so that's why I was looking for a pic.
for anyone that reads this thread and needs that info here's the
best thread I've found re: connector attachment
based on this I'll give it a shot.
m(a)ce, try this ---> stu-offroad.com/misc/rfconn.htm
Old Jan 29, 2009 | 03:27 PM
  #192
Anglah's Avatar
From: Sitting on top of the world with my legs hanging free
Originally Posted by cub23
I got everything I needed in 1 package at a good price.Try looking at this rightchannelradios.com/jeep-offroad-cb-radio-106/jeep-off-road-cb-kit-cobra-75-wx-st-419.html its a pretty good deal.
Cub23, which mount did you use?
Old Feb 10, 2009 | 11:09 AM
  #193
m(a)ce's Avatar
JK-Rubi
thank you. i'll have time tomorrow to hit this. I appreciate the visual double check.
Old Feb 11, 2009 | 08:55 AM
  #194
m(a)ce's Avatar
Weather was up into the 60's today (from the 30-40s). Got a chance to solder the connector on. I think I was definitely over thinking it. Thanks for all the info.
Finished up connections, slapped on the antenna and it worked.
Didn't meter it (hope to soon)
Weather station come in pretty darn good.
Checked out a couple trucker conversations. Reception was not as good as weather - some conversations were understandable some were kinda crackly.
Would this just mean I need to find someone with a SWR and adjust?
Old Feb 11, 2009 | 11:04 AM
  #195
Hoovis's Avatar
That is all pretty normal. The weather is on a stronger signal, so it should always sound quite clear. The clarity of the conversations you pick up will depend on how close and/or strong the signal is.
That being said, if you ever want to transmit out, you really do need to tune it to keep the radio from eventually frying itself.
Old Feb 12, 2009 | 09:42 AM
  #196
m(a)ce's Avatar
Roger that -thank you. Over & out.
Old Feb 19, 2009 | 04:28 PM
  #197
stevedolce's Avatar
I got mine today, but how does the antenna mount to the teraflex bracket? i THOUGHT i ordered everything i needed from quadratec, but is there an adaptor that connects the coax cable to the antenna?
Old Feb 19, 2009 | 04:31 PM
  #198
Hoovis's Avatar
There is a part you need, which I believe is called the "stud." If I recall correctly, the stud goes through the mount, and the coax and antenna attaches to the ends of the stud.
Old Feb 19, 2009 | 05:48 PM
  #199
JK-Rubi's Avatar
This thread has pics of the type of stud you'd need (although pics depict stud for a firering coax) ---> https://www.jk-forum.com/forums/jk-cb-ham-radios-128/installation-firestick-firefly-antenna-spare-tire-mount-59752/
Old Mar 8, 2009 | 09:28 AM
  #200
JKinNNY's Avatar
Originally Posted by Jarne
Here is mine:
I left the fuse sticking out under the console incase I ever needed to change it.
Antenna mount is same as gf4phlyer with spring.
Jarne, thanks for the pics. I too have my WX75 mounted under the glove box, but with the mic cord dangling from the panel below, it get's knocked around by co-workers legs, and the wife's purse. When spring has sprung (we still have snow on the ground), and the temps are more tollerable, I'll have to pull out the console and do a relocation to the same spot you put yours. How's it holding up to items in the cup holders?
E
