My Cobra 75 CB and antenna install
Old Jan 21, 2009 | 09:32 PM
  #181
cub23's Avatar
I got everything I needed in 1 package at a good price.Try looking at this rightchannelradios.com/jeep-offroad-cb-radio-106/jeep-off-road-cb-kit-cobra-75-wx-st-419.html its a pretty good deal.
Old Jan 21, 2009 | 10:52 PM
  #182
odin725's Avatar
Originally Posted by PCHSahara
thx for the info rohantmh! not sure i like the idea of "only cb" vs radio/etc at one time.
I have a 2 to 1 plug for the aux input. i think im going to see if it will allow me to play both my cb and ipod at the same time, because like you it would kill me to just be able to use one or the other.
Old Jan 22, 2009 | 01:25 PM
  #183
cub23's Avatar
Got mine installed today.
Old Jan 23, 2009 | 10:06 AM
  #184
m(a)ce's Avatar
anyone have a pic how they assembled the coax cable to the plug?
not sure if I'm over thinking this or not. but its finally warm enough here to install and just wanted to double check on my first CB installation.
did you solder it?
Old Jan 24, 2009 | 09:08 PM
  #185
RickM610's Avatar
I did my install similar to Cub23 and there was no soldering involved at all!
did you solder it?
Old Jan 24, 2009 | 11:06 PM
  #186
Hoovis's Avatar
did you solder it?
Yeah, I am pretty sure it is just plug in, or screw in like any other coax connection (think cable modem wire). Should be no soldering.
Old Jan 25, 2009 | 06:23 AM
  #187
JK-Rubi's Avatar
did you solder it?
Some coax "kits" require a little soldering - do a search for some good write-ups.
Old Jan 25, 2009 | 09:15 AM
  #188
m(a)ce's Avatar
thanks for the input/info.
I did a search for coax & soldering and only yielded text so that's why I was looking for a pic.
for anyone that reads this thread and needs that info here's the
best thread I've found re: connector attachment
Originally Posted by JackMac4
scissorz - here's what you do:
first put on the rubber boot and slide it down a bit. It's just a cover for later. he narrow end goes on first. Then you'll put that outer sleeve on the wire and also move it down and out of the way.
Next you'll put the wire up and into the main connector. You'll want to fill up the side holes and end with solder using a soldering gun. It's a bit of pain, but just takes a bit of patience. Once its filled and solid, you twist that sleeve on -- it first secures to your main connector then will secure your connector to your CB base unit.
based on this I'll give it a shot.
Old Jan 25, 2009 | 10:03 AM
  #189
cam813's Avatar
Originally Posted by TORN
I would like one of the mounts for rear tire but couldnt find it on quadratec site or catalog, any info on how to get one would be appreciated.
Teraflex make a similar antenna mount.
Old Jan 25, 2009 | 10:55 AM
  #190
rubican!'s Avatar
when i did this mod i had to solder mine but it was super easy
