My Cobra 75 CB and antenna install
Old Mar 28, 2011 | 09:18 AM
  #291
Hoovis's Avatar
Originally Posted by dubyas-eep
what is everyones comments on the 75, other then sound, will probably use the cable to the aux.
reception? convience? troubles? pratical?
Mine was only so-so (albeit adequate on the trails) when I had an antenna that would still clear my garage. Seems to work great now that I have an antenna reaching about 18" above the roofline. Don't even need to use the Aux if everything is tuned and installed correctly. No complaints when everything is done properly.
Old Mar 29, 2011 | 10:01 PM
  #292
JeepFrog707's Avatar
Same here....I have no complaints. It's loud enough for what I need, looks good, stores easily, and I have my firestick high above my roofline. And it's tuned in properly. I really like the fact it quick disconnects for when not in use. And the range is great. Clarity is great too for me so far.
Old Apr 1, 2011 | 11:58 AM
  #293
Myrt's Avatar
Originally Posted by JKjeepguy
I installed my Cobra 75 almost exactly as the OP with one exception...I didn't want to wire mine directly to the battery because I didn't want the CB to be left on accidentally and drain the battery. So I went to Autozone and bought an "add a fuse" or fuse tap and wired it into fuse slot M37 in the fuse box next to the battery. I also cut a small slot out of the fusebox so the lid will close with the wire going into it. See pics below...
Thanks for the info, I'll probably do the same. Really helpful knowing which fuse slot you used.
Old Apr 1, 2011 | 12:20 PM
  #294
yellowtj02's Avatar
so i am curious if this cb has an aux port that you can plug a pa system into? i see on some of the other posts that it has one to plug in an external speaker, but what about for a pa?
Old Apr 1, 2011 | 05:32 PM
  #295
Deere_Jeep's Avatar
No PA that I'm aware of, just the external speaker.
Old Apr 1, 2011 | 06:45 PM
  #296
bingote's Avatar
Yep. No PA
Old Apr 1, 2011 | 08:02 PM
  #297
emoody007's Avatar
Why oh why, do I keep coming on to these threads and looking at all these bad A$$ installs of cool stuff. Now I have to have the Cobra 75 mounted up like this. This has to be the most expensive Web Site in the World. It's a good thing Jeeps have good re-sale value, my accesories and mods are already creeping up on my MSRP.
Old Apr 1, 2011 | 08:15 PM
  #298
Rubichronic's Avatar
I ordered a Cobra 75 because of this thread. Your right, this forum will end up costing me a fortune...but I'm ok with that! Not so sure about me wife...
Old Apr 2, 2011 | 05:35 PM
  #299
User 122117's Avatar
I have mine all hooked up like the OP. One of the numerous great ideas on the forum.
Old Apr 2, 2011 | 09:34 PM
  #300
RedDavid's Avatar
Very nice, what is M37 for (because i'm too lazy to go lift the lid and look )? When i wired my second battery solenoid they had me tap some pink stripped wire that's under the fuse box a real PITA. I've since removed it and been w/o the second battery. Not wanting to muss up that pink wire any more than i did.
