My Cobra 75 CB and antenna install
Old Apr 22, 2011 | 03:39 PM
  #311
Myrt's Avatar
Default Thanks
Thanks a lot for this thread, Installed mine this weekend. A couple of different options i used were...
Used the Flag mount from Quadratec, it gets mounted to the passenger side of the tire, made of aluminum instead of stainless, and only $36
Also was able to fish the antenna coax through the cloth casing on the door without too much trouble.
Everything else is about the same. Thanks again!!!
Old Apr 22, 2011 | 04:53 PM
  #312
JMOE's Avatar
Default How long is the line from the mounted box to the passenger panel?
Was wondering how long the line was that runs from the box to the panel? I would like to complete the same set up but place the connection on the flat spot behind the shifter if possible. Your install looks great "nice and clean".
Old Apr 22, 2011 | 05:50 PM
  #313
BLK08JK's Avatar
The first page of the instruction manual says 10-foot flexible cord... not sure if that's for the disconnect panel or not.
https://www.cobra.com/Manuals/75WXST.pdf
Old Apr 22, 2011 | 05:53 PM
  #314
BLK08JK's Avatar
Maybe a dumb question here, but can I use a spring and a quick disconnect together with the antenna?
Old Apr 22, 2011 | 07:22 PM
  #315
Flaxbourton's Avatar
Awesome thread. Pretty much sold me on the 75. Such a clean install too!
Old Apr 22, 2011 | 07:42 PM
  #316
rocNrow's Avatar
Looks like a clean install! Personally I like a spring on the antenna, the higher the antenna is, the better it works. I stuck a tennis ball on the antenna where it bumps the roof and its flexiable enough to go into my garage.
Old Apr 22, 2011 | 07:43 PM
  #317
rocNrow's Avatar
Yes you can use a spring and quick disconnect together.
Old Apr 23, 2011 | 05:20 AM
  #318
OH9JK's Avatar
JK-Forum Ambassador
Just be sure to check SWR again after adding/removing accessories since it changes the length of the antenna.
Old Apr 23, 2011 | 07:04 PM
  #319
LordEgg's Avatar
i want to thank the OP on this. ive done this and love it. im using a magnetic antenna on the hood for now but the inside job looks great.
and thanks to a fellow forum member, oruacat2, for his help as we had "Jeep Day" at my place doing little mods to our stuff.
Old Apr 30, 2011 | 04:54 PM
  #320
Ragnar JK's Avatar
Thanks to the OP on this one....just finished the install and extremely happy with it....
