My Cobra 75 CB and antenna install
Old Aug 17, 2011 | 05:49 PM
  #371
iamluvinlife's Avatar
Hey guys....im trying to find the hole in the firewall to run the power but im struggling with it. Can someone give me some guidance on how to remove the right air vent? I've tried to spin it 1/4 turn in each direction but I feel like I'm going to break it.
Thanks!
Old Aug 17, 2011 | 06:02 PM
  #372
rpaulson's Avatar
Press in on the BEZZLE around it and turn the BEZZLE a quarter to the left. Should slide right out then.
Old Aug 17, 2011 | 07:09 PM
  #373
Thanks I'll try that tomorrow. I ordered the kit from rightchannel radios. It came with an 18" cable. Any idea what that's for?
Old Aug 17, 2011 | 07:11 PM
  #374
dogsonparade's Avatar
For your antenna -> CB
Old Aug 17, 2011 | 07:19 PM
  #375
It's only 18" though. I have an 18' one I'm running from the tereflex to the unit.
Old Aug 17, 2011 | 07:22 PM
  #376
Sorry- didn't notice the " vs '
It came with an external speaker?
So either the speaker or the swr meter jumper
Old Aug 18, 2011 | 03:40 PM
  #377
thanks you are right it is for the meter.
Old Aug 22, 2011 | 10:57 AM
  #378
tcdawg's Avatar
Thanks!
Remove the side panel from dash on the right side. I know someone mentioned removing the vent bezel first to push out the side panel but I have just used a wide putty knife to pry out the side panel. It is just clipped in and comes right out.
Once you have the side panel out, you'll see the foam filled hole, about the size of a quarter, that runs in under the hood. You can use a wire coat hanger or a wire fish tape.
Old Aug 22, 2011 | 01:01 PM
  #379
Thanks. I was able to get it all installed. Unfortunately I broke the end of the coax after I ran it through the jeep. I over tightened it. The good news is that right channel radios is sending me a new one for free this week along with a quick disconnect.
Old Sep 14, 2011 | 03:38 PM
  #380
JCS78's Avatar
Just installed this and it is awesome!! I haven't put a meter on it but the people that I've been able to talk to say it sounds great.
