My Cobra 75 CB and antenna install
Old Apr 4, 2012 | 10:07 PM
  #481
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
If you cant find one at Radio Shack, try checking a local truck stop.
Then there is also Amazon, Iv seen them on there for fairly cheap.
Hope this helps.
Old Apr 6, 2012 | 05:03 PM
  #482
JeepersLife's Avatar
Thanks for the help guys. I went to a CB shop last night and he fine tuned it enough to where I'm good to go on all channels and they are maxed out on signal strength.
Old Apr 9, 2012 | 03:23 PM
  #483
hobbz's Avatar
I like that cobra 75 for a clean install
Old Apr 9, 2012 | 04:22 PM
  #484
Big Dawg's Avatar
How did you drill the two holes to mount the box. Can you fit a regular drill in there, I notice the bottom panel dosen't remove anymore.
Old Apr 10, 2012 | 04:06 AM
  #485
evoviii2jk's Avatar
I just zip tied the box under the glove box. No need to drill it down
Old Apr 10, 2012 | 04:58 AM
  #486
HG07JKRubi's Avatar
Yea...not sure on the new interior how you'd get to it with a drill but if I remember right, on my '07 I drilled from underneath and used a few self tapping screws to mount the box to the glove box bracket as shown. I have seen plenty of people zip-tie but I opted to screw it down.
Old Apr 10, 2012 | 05:04 AM
  #487
MTG's Avatar
MTG
Ditto. I used a piece of industrial Velcro first and then decided two zip ties would provide even more stability. Works perfectly.
Old Apr 11, 2012 | 10:03 PM
  #488
Devildoc's Avatar
Here are some pics of how I mounted mine. Only the 2 screws for the mic clip are the only thing I had to cut or screw into the dash. I ran the coax into the tailgate an under the carpet until the door trim and ran it all the way to the box. 18ft was a perfect fit.
ID:	302849   Click image for larger version
ID:	302850   Click image for larger version
ID:	302851   Click image for larger version
ID:	302852   Click image for larger version
Old Apr 18, 2012 | 06:47 PM
  #489
Infinutty's Avatar
Default 2012 Install question/request
In a 2012, anyone have pictures of where to route the wires from the remote box to the battery? Perhaps I'm just blind and I certainly didn't spend a long time looking once I realized the images I was viewing online were from a 2007-2010 model interior. To me it appears as though there's enough changes with the 2012 between the new interior/dash and engine that this part of the install doesn't get covered :( Perhaps I need to get some wire to extend the power and ground lines or move the remote box to the driver side? Any tips + pictures greatly appreciated!
Old Apr 18, 2012 | 07:20 PM
  #490
keithvegas's Avatar
You can splice into the 12v accessory plug (cig lighter) in the center stack. It switches on and off with the key. For constant on use the jack in the center armrest.
