Old cb
Old Oct 22, 2012 | 03:55 PM
09jku's Avatar
Default Old cb
Ok can any one tell me if my old cb that I have had for years and have swapped from vehicle to vehicle and now my my jk. It's a cobra soundtracker I haven't used it in a long time but worked when I took it out of my old truck. My other issue is where to mount it, the antenna, and what size and make of antenna to use?
Old Oct 22, 2012 | 04:37 PM
familytime's Avatar
JK Forum Regional Rep
Should work,i'm using one that had since the early 80's and works great.I'm using a 4' firestik mounted to the tire carrier
Old Oct 22, 2012 | 04:58 PM
09jku's Avatar
Cool :-). How did u mount both? Where do I get good cable and stick for cheep?
Old Oct 22, 2012 | 05:05 PM
familytime's Avatar
Mounted the cb above the rear view mirrior,The antenna is mounted on the tire carrier using the supplied bracket from the antenna kit.The antenna i got as a kit,a good off road store would have this or check your local listing for 2-way communication equipment.
Old Oct 22, 2012 | 05:07 PM
09jku's Avatar
Do u have a pic of the mounts by chance? .........z
Old Oct 22, 2012 | 05:23 PM
familytime's Avatar
Check out write ups for mounting tips for your cb,thats what used,
Old Oct 22, 2012 | 05:31 PM
09jku's Avatar
Oh thanks that helps
