Places to mount a PA speaker
Old May 13, 2009 | 05:16 PM
DeluxeJK's Avatar
Default Places to mount a PA speaker
What yall got?
Old May 13, 2009 | 06:21 PM
DeluxeJK's Avatar
Im open to any ideas or suggestions too
Old May 13, 2009 | 07:13 PM
Vernnz's Avatar
Haven't done it (yet) but from some of the posts I have seen.
1. Under the steering wheel. Non-Infinity sound systems are easier since there isn't an amp.
2. Someone quite a few posts ago found one small enough to fit in the roll bar. He or she took out the corner foam piece, cut out a notch for the speaker and put the velcro cover back over it. That one is kind of neat because it is almost like a headphone speaker in the dribers left ear.
3. CB with front firing speaker instead of up or down firing. If you can mount it pointing at you is half the battle.
Now for a few guesses...
1. Cut out the roll bar speaker box and put one there.
2. If your H/U has a 3.5mm input jack you could just plug it in there and select the AUX port.
Like I said I haven't put one in yet but I just got my CB running a few hours ago.
Old May 14, 2009 | 03:50 AM
Preacher's Avatar
I thought the OP wanted a PA speaker, not an external speaker for the CB.
There seems to be plenty of room under the hood...
Old May 14, 2009 | 12:08 PM
LazySumo's Avatar
What's the difference? Top off and doors off and those 7 Infinity speakers are going to be about as PUBLIC as you can get!
Old May 14, 2009 | 06:55 PM
Vernnz's Avatar
I'll just shut up now.
Old May 14, 2009 | 08:31 PM
LazySumo's Avatar
LoL, wasn't trying to be a dick about it, apologies. I guess the real diff is if you jack the CB into the AUX then you can't listen to tunes. Anything else tho?
Old May 14, 2009 | 08:51 PM
DeluxeJK's Avatar
yeah there seems to be room just not a great place to mount it. Just wanted to see if anyone else had some great ideas but i guess not many are running a PA. Thats interesting running it to the AUX input though....
Old May 14, 2009 | 09:05 PM
Vernnz's Avatar
Didn't take it that way. I was laughing when I typed that.
Old May 15, 2009 | 04:12 AM
Preacher's Avatar
The other thing to consider is that plugging the external speaker output from the CB into the AUX jack, you have to keep the CB volume WAY down. The output from most CBs is around 3w and I would think that is right at the max limit for the AUX jack. It DOES work, I have done it, but it is not an optimal solution.
In fact, I built an A/B switch box so I could plug both the CB and my iPod into the Aux jack at the same time. With the switch, you can choose your input source. I used it for all of 1 day and then threw it in to the glovebox.
Plugging the PA output on the CB into the AUX jack would probably fry something.. LOL I think the PA output puts out more than the 3w the external jack does.
