Question for Cooltech customers
Old May 30, 2009 | 07:29 AM
opdsgt's Avatar
Question Question for Cooltech customers
The interior of my 2-door is completely Line-X'd, so I have not a stitch of carpet to hide any cable under.
For you guys who have the Cooltech LP antenna mount: is the supplied 18' coaxial cable long enough that I will be able to route it from the LP mount all the way to the front of the interior and across the header via the ROLL BAR PADDING so I can install a CB above the rear view mirror?
Thanks for the input.
Sarge
Old May 30, 2009 | 07:05 PM
opdsgt's Avatar
Thanks for the input, fellas. I will give it a go and report back with how my final routing goes.
Old May 30, 2009 | 07:29 PM
CRUISER1027's Avatar
I have a 4-door and had to get a 6 foot cable to make it work.
Old May 31, 2009 | 06:17 AM
opdsgt's Avatar
I'm a pretty busy "fella" - no way I could know the gender of all the forumites here...
Old May 31, 2009 | 07:19 AM
donnie's Avatar
From: Simi Valley, Ca., Taylorsville, Ut. and places in between
Thinking about using the same system on mine.
I take it you used a barrel connector to connect the coax.
How well did it match after the install?
Im also wondering if using a 102" antenna and spring will work with the Cool Tech mount.
Iv got two or three in the garage.
Thanks.
Old May 31, 2009 | 12:44 PM
opdsgt's Avatar
I know, brother. Or sista.
Old May 31, 2009 | 05:06 PM
utah-jk's Avatar
Unless Cool Tech has decreased the length of coax that they give you in their kit, I easily mounted the antenna in the license plate and routed the coax through the roll bar padding, mounting the CB at the rear view mirror. I had a couple of feet of coax to spare. And I have a 4 door!
Old Jun 1, 2009 | 04:39 AM
opdsgt's Avatar
Utah, that's great news. That's the way I'll have to route my cable since my interior is Line-X'd. Thanks for the positive vibe, I've go hope now!
Old Jun 5, 2009 | 04:03 PM
mmcan's Avatar
I ran mine from the right sided bumper mount thru the padding on the roll cage to the front passenger side, into the molding along the a pillar on the side of windshield and into the unit loacted under the glove box near the console.\
Length is not an issue for me,...
