Recieved CB today
Received CB today. Waiting on antenna and cables but decided to get it ready for install. I'll post pics when it's fully complete, but here it is for now.
Thanks to everyone on the forum who has helped me out
Today....mounted antenna
anyone know what the last thing is?? Didn't say anything on the directions - it also said use the longer bolts for the mount .... which I didn't even need. I also attached a quick disconnect... is this all I have to do as far as the antenna or am I missing something??
did you run a ground wire? and I think you use longer bolts when there are spacers to push the antenna off the carrier. I'm not 100% though I'm sure someone who has that bracket will chime in. It looks good thought buddy.
you should be fine. that mount typically gets a good ground at that spot but you can run into problems of dead spots in your hinge swing if you TX with your gate open. If you ahve funny problems with feed back and RF noise in your audio let us know and we can talk you through grounding the mount.
YMMV
YMMV
YMMV
YMMV
Also is tuning easy? How do you do it??
