Redo'ing my CB setup for backcountry travel
Old Dec 21, 2015 | 12:23 PM
Kojack's Avatar
Default Redo'ing my CB setup for backcountry travel
Well, my little realistic cb crapped the bed recently so I am in the process of upgrading my entire system. I am going to use the uniden 520xl radio for compact durability. Then I am adding a 100w linear amplifier to get longer distance between vehicles and still have communications. I am topping it/or backing it off with a 3ft firestik II. That will keep most of the antenna out of the way of brush etc while on the trails.
Now, before anyone jumps on the legal bandwagon pedestal, we are 100s of KM out of civilization and there are no towns, cities etc anywhere close. Plus, I won't be blasting music, preaching, and otherwise being a nusance over the airways. Its simply to be in touch with other vehicles in the back country. The good thing is that the amplifier also helps with receiving as well as transmitting From what I have read.
Old Dec 21, 2015 | 12:39 PM
Mark Doiron's Avatar
Okay, I won't lecture. But a linear amp, by itself, will not improve reception. Some enterprising fellow (bear in mind, you are dealing with and trusting someone who knows he is breaking the law) may have incorporated some sort of pre-amp into his linear. And there are certain cases where a pre-amp could improve reception. But those cases involve long lines of coax, and mounting the pre-amp at the antenna, not in the linear.
Honestly, if you can't get the performance you need from CB, maybe you and your friends should look into ham licenses. Here in Oklahoma we're holding classes to help four wheelers earn their licenses. A 2-meter radio, using common repeater networks, can easily talk anywhere within reason.
Old Dec 23, 2015 | 09:21 AM
Kojack's Avatar
The other thing mark, we don't have a reliable repeater system here anymore I don't think.
Old Dec 27, 2015 | 02:37 PM
Owl's Avatar
Owl
IMO, the very best thing you could do is to buy / build a dipole (full size half- wave) antenna, resonant on the CB emergency call frequency (at least I think that there's one so designated). Figure out a means of getting it up in the air (> 35') while out on the trail. Make sure you have enough feed-line / coax to get back to the radio.
I'd also look into a CB rig with side-band capability, if there isn't any interest in Ham radio.
Old Dec 27, 2015 | 04:06 PM
Owl's Avatar
Owl
To clarify:
I wouldn't expect you to try my suggestion whilst mobile........ Rather, when parked / at a camping spot.
Old Dec 28, 2015 | 02:00 AM
Kojack's Avatar
Kinda figured! ha ha.
I have been in contact with the amateur radio club and the president actually told me that there are 3 repeaters that cover the entire area that we travel in the most. Never knew it. but they are 100kms away. Is he correct? that I can trip a repeater say 200kms away and get in contact?
Old Dec 28, 2015 | 09:19 AM
jchappies's Avatar
60 and 120 miles are very do-able with a HAM radio, what kind of power are you putting out with your ham? Do you know what the repeater TX power is? Is this 2M, 70CM??
Old Dec 28, 2015 | 10:03 AM
Owl's Avatar
Owl
Repeaters are a very useful communication method, however they have limitations. The frequencies used for these relay devices are VHF and UHF (very-high frequency and ultra-high frequency). These bands are typically "line-of-sight". So, if you can see the mountain-top, or know that the repeater location is high enough, the distance you show aren't a problem. Also, if you can't hit the repeater from a low lying area, then all that needs to happen is for you to move to higher ground (for the most part - this is a simplistic explanation).
Get with the folks at the club for more information. You might find that amateur radio is a very worth while endeavor, and goes very well with off-road activity.
Old Dec 28, 2015 | 12:36 PM
Kojack's Avatar
Cool, I am going to re do my CB setup as mentioned and see what happens. And then if not satisfactory, move to vhf radios.
Old Feb 27, 2016 | 11:49 AM
jlocker's Avatar
Any luck with your cb setup?
