Sissy Bar
Been meaning to take the time to post this for a few months now.
All for around $10 you can build a "sissy bar" that makes a very nice antenna mount. A 4' stick of .5" EMT cut in half, a couple of couplers, 2 EMT elbows and 4 longer bolts from your local auto parts store is all it takes.
Put it all together, drill a few holes and you're set.
Once it's all together, it's already a perfect fit that lines up with the outer bolts on your carrier.
It just might be good for that as well. I've had it on for a few months now and it's still very sturdy. I suppose going 3/4" emt would work just as well. I used 1/2" because the antenna mount was designed for it. I'm sure it would hold an array of multiple antennas for someone running a wide range of freqs. As soon as I get some free time I'm going to clean it up and hit it with a couple coats of black paint to make it blend in better.
Thanks. I've been running a wilson 1000 on top of my 148gtl for nearly 20 years now. Sure a shorty is great for keeping in touch with your trail mates when out on a run, but I don't feel like I'm getting out unless I can talk around the globe from my own driveway :-)
Since I don't want to modify my hard top to take the wilson 1000 on direct center, I settled for the wilson 2000 on the backside.
Mine is still very solid and doing a fine job.
Thanks for looking.
