So where have you been mounting the CB's?
Old Jun 2, 2012 | 05:36 AM
  #201
gunngee_.300's Avatar
You might also want to try "Gear Keeper" and attach it to the footman loop or passenger shade flap.[/QUOTE]
What is "Gear Keeper"? I do a google search on it and it comes up with scuba stuff.
Old Jun 2, 2012 | 05:47 AM
  #202
conifers4's Avatar
What is "Gear Keeper"? I do a google search on it and it comes up with scuba stuff.[/QUOTE]
Try this...CB MIckeeper
Old Jun 2, 2012 | 10:02 AM
  #203
Rooster76's Avatar
Wink Gear Keeper for CB's
Might want to do a search for "Gear Keeper CB". I guess the company started out making retractables for scuba stuff and then branched out to other things. They have a hoop that goes over the button to hold the mic. From what I have read you can adjust the length you want it to hang at. You should be able to find one for less than $10. Here is some pictures.
Old Jun 2, 2012 | 03:16 PM
  #204
FlameRedJK's Avatar
Originally Posted by Rooster76
Good Call, it makes a nice radio pillow I just happened to have some of that laying around. It might be a bit overkill but it's not hurting anything.
I think it will work for you on the footman loop. It looks like yours has actually a smaller depth from the right channel radio site.
The uniden 520 has dimensions of 4-1/2" W x 6-3/4" D x 1-3/8" H
the cobra 18 has dimensions of 7" W x 6.5" D x 1 7/8" H
I put a 90 degree connector from Radio Shack on the back of my radio for the coax so it wouldn't bend against the window. After it was mounted i realized that I probably didn't need it with the small PL-259 connector of the Firestick Firering coax.
Radio Shack
PL-259 Inline Right-Angle Adapter
Model: 278-199 | Catalog #: 278-199
You might have to drill a hole in the supplied mount to put the L brackets on? That's no big woop, I think you should be good.
FlameRedJK just used zip ties on his footman mount. You might try that to see how you'll like it and if it will fit. I did this myself before I got all my parts.
Good Luck,
I ended up swapping out the foam for Velcro as you can see in my pic. Zip ties and Velcro worked so well, it's still like that haha...I intended on coming up with something more elaborate but, if it ain't broke don't fix it ;-)
Cost all of maybe 2 bucks to put that together, already had a bazillion zip ties laying around, just needed to buy some Velcro strips.
I also used a right-angle adapter on the back end so it wouldn't touch the windshield, worked like a charm!
Old Jun 2, 2012 | 03:19 PM
  #205
FlameRedJK's Avatar
Originally Posted by Hondo1
Perfect fit out of the way in center console. With a 3 ft. firestick on a spare tire mount works great.
I like it, would like to do the same with mine.
Old Jun 3, 2012 | 07:43 AM
  #206
Amro's Avatar
Attachment 324583
Attachment 324584
I've got some serious commo envy going on over your set up. I just got my 2012 JK and the weekend was my radio mounting project for it. Not a CB, HAM Yaesu FT-8900r and plan to get a CB for commo with non-HAMs on the trails.
ID:	324962Click image for larger version
ID:	324963Click image for larger version
ID:	324964Click image for larger version
ID:	324965Click image for larger version
Wanted to keep the radio out of sight of people just walking by, but still accessible to me when I am driving. The main radio unit will eventually go under my seat when I buy a longer power cord and mounting bracket.
Old Jun 3, 2012 | 09:09 AM
  #207
fstopme's Avatar
Mine is a Bearcat 880. Love it.
Name:	BEARCAT 880 0439.jpg
ID:	325002   Click image for larger version
Name:	BEARCAT 880 0438.jpg
Old Jun 3, 2012 | 09:42 AM
  #208
mattgt5's Avatar
Does the uniden 520 have the aux jack to hook up to the radio?
Old Jun 3, 2012 | 02:10 PM
  #209
Rooster76's Avatar
Originally Posted by Amro
I've got some serious commo envy going on over your set up. ...
Holy Cow, you got me beat by a mile. I just have the uniden 520 and no HAM licence yet. I found the pict with a search.
Yes, the Uniden 520 has a 2 holes in the back. One is for a PA and the other is for an external speaker (which is the one you would use) . You can get some 3.5mm (1/8") plug male to male wire and it will work. It is a mono connection from the CB radio so it would be best if you could find a mono to stereo jack. Otherwise it will only come out on the left or right side through the stereo.
Old Jun 10, 2012 | 06:19 PM
  #210
coreff15's Avatar
I just installed my Midland 1001LWX over the weekend above my rear view mirror. I used 1/4" insulated clamps. Had to put some muscle into bending the clamps to get the bolt through, but overall I think it is a clean install. Just need to run power to the unit. I am storing the mic in the console while not in use. Drove around the area a little with no issues of movement and the mic cord didn't hinder my view too much, however I don't use my rear view mirror that much.
