SWR meter off the charts. Think meter is busted.
So my SWR readings are off the chart. I thing its my meter. The male connectors are shorted to each other. M getting continuity between the inner and outer rings on both connectors. Doesn't matter if its on the antenna side or the transmitter side. Does it make sense? Help
Anyway, don't check RF cables for shorts with a VOM unless they are disconnected at both ends. If you get a short between the inner and outer conductors with both ends disconnected, then it sounds like you may have a strand of shield wire draped over the center conductor. Open and visually inspect for this; repair as indicated. Did you make this cable (or attach either connector) yourself, or was it pre-made?
Thought it was my meter. It ended up being the mount. It was missing the plastic ring. I'm getting all my readings at 1.9-2.5. I'll have to figure that out later. I've tried lengthening, shortening, adding a disconnect. Added a ground wire from the frame to the bottom of the mount. I'm tired of looking at the CB. Thanks for the help.
