SWR meter off the charts. Think meter is busted.
Old 09-06-2009, 11:30 AM
abock33's Avatar
Default SWR meter off the charts. Think meter is busted.
So my SWR readings are off the chart. I thing its my meter. The male connectors are shorted to each other. M getting continuity between the inner and outer rings on both connectors. Doesn't matter if its on the antenna side or the transmitter side. Does it make sense? Help
Old 09-06-2009, 11:44 AM
woffles's Avatar
Sounds like your antenna is grounded to the frame. Only the outer cable should be grounded.
Old 09-06-2009, 12:34 PM
Mark Doiron's Avatar
Not sure it makes sense to me. But, remember that when you measure with a VOM, you're measuring with DC what you are actually using for AC (RF is basically a high frequency alternating current). What is a short to DC may not be a short to AC at all. An inductor comes immediately to mind. There are special tools for testing RF cables, but most of us don't have a Time Domain Reflectometer (TDR) sitting around our garages.
Anyway, don't check RF cables for shorts with a VOM unless they are disconnected at both ends. If you get a short between the inner and outer conductors with both ends disconnected, then it sounds like you may have a strand of shield wire draped over the center conductor. Open and visually inspect for this; repair as indicated. Did you make this cable (or attach either connector) yourself, or was it pre-made?
Old 09-06-2009, 01:51 PM
abock33's Avatar
Thought it was my meter. It ended up being the mount. It was missing the plastic ring. I'm getting all my readings at 1.9-2.5. I'll have to figure that out later. I've tried lengthening, shortening, adding a disconnect. Added a ground wire from the frame to the bottom of the mount. I'm tired of looking at the CB. Thanks for the help.
Quick Reply: SWR meter off the charts. Think meter is busted.
