Tail gate ground
I ran a wire from the antenna stud to inside the tailgate, then from the tailgate to the tub. AFAIK, it didn't help a bit. I was talking to a tech who consults w/ Wilson (the antenna people) about an antenna I was having trouble with and I told him about it. He said, "That's a DC ground, not an RF ground."
Read up on "bonding".
My antenna ground is from a bolt on the antenna bracket (see black wire with yellow crimp loop on top bolt of inverted CoolTechLLC GateMount bracked) to the sub-woofer acorn nut (other end of black wire with another yellow crimp loop). Never an issue with grounding. Great SWR. (1=1.4, 20=1.0, 40=1.5)
I've been trying to get decent swr readings for 2 frickin weeks now. One of my fellow jeep buddies told me to ground the gate itself and make it easy. I ran a ground wire from the tub next to the rear roll bar and ran it through the loom with the rear brake light wires and mounted it onto the gate. Swr went from 2.5 and up to 1.5 and below across the band.
I get 1.1 to 1.4 readings with just the RF ground. Had to adjust the antenna to get those numbers.
Originally Posted by Freewill
If the bonding wire (the one you added to the gate) helped your SWR then there could be a problem with the RF ground connections on your coax. The extra bond wire shouldn't hurt anything, but shouldn't be needed either.
Originally Posted by Jeeping4Fun
<img src="https://www.jk-forum.com/forums/attachment.php?attachmentid=344153"/>
Here is my antenna mount. I use a cobra m#75 with a panavise mount and I think it works great. I am curious though as to what range it should operate at.
