What's your set up....
Old Nov 12, 2007 | 06:04 AM
  #21
HEK's Avatar
HEK
yep today on the way to work I had it on scan and nothing, not one soul...wow I hope is not the CB that's damaged ...
Old Nov 13, 2007 | 01:46 PM
  #22
HEK's Avatar
HEK
Originally Posted by N2rock
Did you tune the antenna with an SWR meter?
I just called radio Shack and they said the price was $50 for a SWR meter.. , when I said that I needed it only to calibrate my CB antenna and asked if they rent it...he said..."is returnable".... , do yu think he was trying to say...use it and return it.... ..decisions, decisions......
Old Nov 13, 2007 | 07:50 PM
  #23
07 RBY's Avatar
Originally Posted by HEK
So I got my Midland yesterday and today I just got my Cool Tech antenna / bracket..one thing that is now required is to solder the "nipple" connector to the actual screw on piece that connects to your CB...I saw pictures on a previous thread and there was a connector already mounted on the coax cable..... , why did they send me a cable that needs to be connected and then I have to solder the tip....I'll have to wait now until Monday to borrow one from work...I wish they would have mentioned it and not made a change w/out notification to those who may not have access to a soldering gun or are able to solder...my 2 cents...
Edit my fault....I just read the entire Cooltech instructions and saw that they do tell you that you need to so,der the tip....
It's much easier to run the cable without the connector installed. It's not that difficult to do. I had to do mine twice because I put the thing on backwards! Doh! ANd I was an Electronics Tech in the Navy for 20 years. I will say that I retired almost 10 years ago. You tend to lose it if you don't use it.
Old Nov 14, 2007 | 06:17 AM
  #24
HEK's Avatar
HEK
Well I think that the only problem wher the size of the "fitting" would be a problem snaking thru , would be the rubber grommet in the back of the Jeep, as the rest i was able to just oull back the acrpet and done deal...but I'm all set as I was able to solder the tip as required, thanks to my connections at work....
