Where did you mount....
Old Jul 24, 2011 | 11:57 PM
deconstructionist's Avatar
on a custom overhead "T" running from side to side and from the middle to the sound bar. About the only pic I have of it right now.
Old Jul 25, 2011 | 06:21 AM
JKSLEEPR's Avatar
I mounted mine beside the console on the passenger side. Used the stock torx bolt that was there and fashioned a bracket to attach the CB mounting bracket to that holds secure. No movement, didn't have to drill any holes into the interior and no real impact on leg room on the pass side.
The mic holder is a homemade piece made out of steel plate that attaches behind the radio panel, keeps the mic within easy reach and out of the way as well.
ID:	185905Click image for larger version
ID:	185906Click image for larger version
ID:	185907Click image for larger version
ID:	185909Click image for larger version
Old Jul 25, 2011 | 09:16 AM
4whelin's Avatar
I mounted a Galaxy DX959 overhead...
Old Jul 25, 2011 | 06:26 PM
Ecb12's Avatar
Mine is in my center console. It fit with a right angle adapter for the mic and the antenna.
Old Jul 29, 2011 | 04:13 PM
Weems's Avatar
I mounted mine under the steering wheel. The bottom part of the dash pops out, and I just slid it int here. Looks pretty good!
Old Jul 30, 2011 | 07:06 AM
WXman's Avatar
Total cost: $9.95 (I already had a radio and coax)
ID:	187835Click image for larger version
ID:	187836Click image for larger version
ID:	187837Click image for larger version
Old Aug 10, 2011 | 06:40 PM
8000ft's Avatar
Name:	2011 04 27_0012.jpg
ID:	194014Click image for larger version
Name:	2011 04 26_0008.jpg
ID:	194015Click image for larger version
Name:	2011 04 26_0006.jpg
ID:	194016Click image for larger version
Name:	2011 04 27_0016.jpg
ID:	194017Click image for larger version
Name:	2011 04 27_0019.jpg
ID:	194018home built mount
Old Aug 10, 2011 | 06:42 PM
8000ft's Avatar
just realized that pictures 2 and 3 are using the proto type mount but you get the idea.
Old Aug 10, 2011 | 07:21 PM
PainKiller's Avatar
the upper center dash piece
Old Aug 10, 2011 | 07:34 PM
dogsonparade's Avatar
In retrospect, I should have done it on the center console where the torx bolt is on the drivers side near the right leg.
