Alternator or Alternator + Second battery?
Old Mar 3, 2013 | 09:54 AM
MitchP's Avatar
I want to upgrade my stereo system in the near future but I don't want voltage drops, dimming head lights Etc. I plan on getting this to put in my 2 Door JK (07)
Should I get a second battery for it? Would I have to get a new alternator to support the second battery? Would just a new alternator be fine? Is there anything else I should be considering? (Different box because this probably won't fit?)
Old Mar 3, 2013 | 11:04 AM
shabbernigdo's Avatar
Stock should be fine with some caps if all else fails. Caps and a 2nd battery.
Old Mar 3, 2013 | 11:09 AM
JK-Ford's Avatar
You will need to purchase a "dual charging system" for maintaining two batteries.
Old Mar 3, 2013 | 11:45 AM
MitchP's Avatar
Would an isolator work? Would you recommend a diode or solenoid (relay) version?
Old Mar 3, 2013 | 11:49 AM
JK-Ford's Avatar
Just purchase a system "Off The Shelf".
Search Results - Quadratec
Old Mar 3, 2013 | 03:24 PM
Ryan0260's Avatar
I would start with a good deep cycle battery and see how it does before anything else.
Old Mar 3, 2013 | 03:35 PM
MitchP's Avatar
Like this?
Old Mar 3, 2013 | 04:41 PM
Ryan0260's Avatar
Like this?
I honestly don't know anything about that battery, but that is the right kind. I went with an Optima yellow top and it does great, and costs a lot less than that one.
Old Mar 3, 2013 | 04:58 PM
MitchP's Avatar
Should I worry about what watt output a battery has? I couldn't find it for the Yellow Top.
Old Mar 3, 2013 | 05:29 PM
JK-Ford's Avatar
Yes you need to make sure that the battery matches the recommended CCA ( cold cranking amps ) rating for your Jeep.
