Anyone install a backup camera?
Old Dec 12, 2008 | 02:03 PM
  #21
BlackNorthernJK's Avatar
Originally Posted by Hellbound13
...So Im assuming you guys just drilled through the bumper then secured it with bolts and nuts from behind?...
no...just drilled through the plastic about a 1/4" hole so you can run the wires through up to your reverse light, than used a couple small screws to attach the camera mount to the plastic skin of the bumper, you don't need to worry about drilling through steel here...I suppose if your really concerned the camera may come off you could use bolts and nuts but mines been on for just shy of a year now and no problems at all
...Also does the VR3 have a mount easily allows you to detach the screen?...
...well, yes, but it's kind of a lame mount and I personally didn't use it...you'll have to figure out where and how you like yours mounted and use a little imagination...
...It seems better as the monitor automatically turns on when you are in reverse as opposed to having to switch it on yourself on the VR3.
you don't have to switch the monitor on and off manually with the VR3, monitor is wired to an ignition power source, it comes on when jeep is running but will stay a black screen until it receives a wireless signal from the camera...or oddly enough your local 7-11 wireless camera as they operate on the same band width...so as long as you've wired the camera to come on when in reverse thats the only time it will come on automatically, or if you opt to wire your camera from a button, well than you will manually turn it on and off which to some is the preffered method
go ahead and get yourself the kit, it's cheap but works, it's by no means the Cadillac of systems but it does the job, it's absolutely dead simple to install and you'll figure it out when you just dig in and start
Old Dec 12, 2008 | 08:21 PM
  #22
Hellbound13's Avatar
Thanks for all the feedback man. Gunna go ahead and get one this week.
Old Dec 12, 2008 | 10:09 PM
  #23
