anyone upgraded there headlight/foglight bulbs?
Old Oct 18, 2007 | 10:15 AM
  #31
WikedLizard's Avatar
Default HID's
I have used Silverstars in the past and just was not very impressed with the output vs. cost. So this time I decided to go HID conversion and couldnt be happier. It is like night and day difference.
Old Oct 18, 2007 | 01:50 PM
  #32
CarFanatic's Avatar
silverstars work well??? there only like 20 bucks.
Old Oct 18, 2007 | 06:14 PM
  #33
gundybears's Avatar
I used silverstars too, and they helped a lot. Also, try aiming them, Jeep did a bad job aiming them from the factory.
Old Oct 18, 2007 | 07:25 PM
  #34
Zylfrax791's Avatar
Silverstars don't last very long at all. Not worth the money in my opinion because they burn out anytime after about 3 months. Anyone do an HID conversion yet? As for the Flowmaster, have them redo it, the markings are on the muffler for a reason I'm thinking...
Old Oct 19, 2007 | 05:28 AM
  #35
Um.....
Look at the post above yours. I already posted about my HID conversion.
lmao
Old Oct 19, 2007 | 05:34 AM
  #36
inajeep's Avatar
Originally Posted by River Lizard
Helpful hint.....wear latex gloves when replacing the bulb in case you touch the surface of the bulb. The oils on your fingers can definitely shorten the life of the bulbs.
Assuming I get the gloves and install them perfectly, how long do they last?
Old Oct 19, 2007 | 05:41 AM
  #37
CarFanatic's Avatar
I've reaimed them since the lift, just want some more light out put if possible.
Old Oct 19, 2007 | 05:43 AM
  #38
CarFanatic's Avatar
stock bulb is an H13 right?
Old Oct 19, 2007 | 05:48 AM
  #39
HappyCurmudgeon's Avatar
Eternal ***erator
I have the Silverstars, they are a decent upgrade for the money.
From the Service Manual (I have it dogeared, i keep forgetting when people ask-guess i'm not a bright bulb. *L*)
Pg. 393/394
REPLACEMENT BULBS — IF EQUIPPED:
Interior Lights Bulb Type
Auto. Trans. Indicator Light . . . . . . . . . . . . . . 658
Courtesy Lights, Under Dash (1). . . . . . . . . . . 906
Heater Control Lights (2) . . . . . . . . . . . . . . . . 194
Rocker Switch Indicator Light
(Rear Window Defogger, andRear Wash/Wipe) . . . . . **
Soundbar Dome Light . . . . . . . . . . . . . . . . 912
** Bulbs only available from authorized dealer.
Instrument Cluster Bulb Type
Telltale (High Beam) . . . . . . . . . . . . . . . . . . . . 74
Illumination . . . . . . . . . . . . . . . . . . . . . . . . . 103
Exterior Lights Bulb Type:
Backup Lights (2). . . . . . . . . . . . . . . . . . . . . 3157
Center High Mounted Stop Light (1) . . . . . . . . L.E.D.
Fog Lights . . . . . . . . . . . . . . . . . . . . . . . . . . 9145
Front Park/Turn Lights (2) . . . . . . . . . . . . . . . 3157
Front Side Marker Lights (2). . . . . . . . . . . . . . 168
Headlights (2) . . . . . . . . . . . . . . . . . . . . . . . . H13
Stop/Tail/Turn Lights (2) . . . . . . . . . . . . . . . . 3157
Underhood Light . . . . . . . . . . . . . . . . . . . . . . . 561
License Light . . . . . . . . . . . . . . . . . . . . . . . . . 194
Old Oct 19, 2007 | 06:03 AM
  #40
CarFanatic's Avatar
thanks! I might pick up the head and fogs after work today!
