Aux light switch feed. noob question
Old Dec 29, 2010 | 05:45 PM
chknkatsu's Avatar
Default Aux light switch feed. noob question
i've read so many FAQ's already regarding light installation. for my aux light i want it to be on its own circuit. so i can turn it on whenever i want.
all of them say tap into the fuse box for the switch feed. but which fuse do i use? i want to be able to turn the lights on whether my car is on or off.
which fuse's have constant power?
Old Dec 29, 2010 | 08:10 PM
genesbro's Avatar
Just use a fused wire from the batt + post to do what you want to do and forget the fuse box.
Old Dec 30, 2010 | 06:34 AM
JK-Ford's Avatar
Hope that you are good at battery maintenance.
Old Dec 30, 2010 | 06:44 AM
Orangeav's Avatar
Why? I'm not sure I understand. Battery drain or corrosion? I ran a fused line to the relay and a fused line to the switch. Should I be worried about battery problems? Please elaborate!
Old Dec 30, 2010 | 10:44 AM
JK-Ford's Avatar
Originally Posted by Riptide
Agreed... As long as you're turning the lights off when the JK isn't running (or not leaving them on long enough to kill the battery), it shouldn't matter...
That is exactly my point!
chknkatsu
Old Dec 30, 2010 | 01:15 PM
Orangeav's Avatar
gotcha!
Old Dec 30, 2010 | 01:42 PM
chknkatsu's Avatar
awesome, thats the answer i was looking for. im an electrician but all this "use the fuse box" thing was confusing me. as for the rest of the wiring i have it under control. thanks guys
Old Dec 30, 2010 | 02:07 PM
HotFrosty's Avatar
I have found (for me at least) that I never run only one thing to the fuse box. One of the first things I do is wire up a second fuse block to the inside of the cab so I can have a switch for the lights, and the CB, Oh! and then the Strobe lights, disco ball and 5 TV's.
You get my drift. It just makes things easier in the long run.
Old Dec 30, 2010 | 05:25 PM
chknkatsu's Avatar
Originally Posted by ECHO
I have my lights set up use when I want, but; i also have a dual battery set-up which means I have a battery dedicated to accessories and one for starting hwne the vehile is not running.. You also have to keep in mind that Aux lighting gets very hot and the movement of the Jeep helps keep them cool, which mean better bulb life and cooler enclosures
alright i will definitely keep that in mind. thank you. i want to do the dual battery setup. when i have the funds im definitely jumping into it
