Boooooring electrical ground question
I found a broken grounding strap bolted to the passenger side of the transmission. Looks like it failed right next to the cat. I haven't found the other end yet, anyone have any idea where this goes? Where I should look? I am having some wonky electrical problems so this might be an easy fix for one or more of those! I can get a pic if that would be helpful, probably should have done that already huh. I'll get one. In the meantime, any insight would be appreciated
got a pic by chance? i just went out and looked at mine but couldn't see what you might be talking bout. with skids on it's kinda tight quarters to see, but didn't see anything obvious there on passenger side. Maybe it's only there on the manual tranny??
I grabbed a few pics and the ground is on the block and not the trans. I checked that hood/firewall ground location in the above photo from OnBelay (belay is on). I have no strap from the firewall to the hood and the only connection from that stud is to the negative battery terminal. I have a dual battery setup that makes it a little more challenging to get a good look in there but I'll take some time tonight and open it up.
The block end (rusty bolt dead center):
Under the hood. No ground strap, though the stud is there. I removed the hood once to cut holes for the hood louver, maybe I forgot to put the strap back on? That seems unlikely but nobody's perfect
