Cabin Air Temperature Sensor Location?
Old May 10, 2021 | 08:09 PM
  #51
Lenicus's Avatar
Default Can't locate 2017 jeep renegade latitude
Originally Posted by mattro
Does anyone know where the following sensor is located? I have the sensor just have no clue as to where to install it.
SENSOR. Temperature Cabin Air.
Stock Code 55111178AC
Description: SENSOR. Temperature Cabin Air. . "Instrument Panel Parts Module"+"Air Conditioning w/Auto Temp Control". Required: 001
I upgraded my AC/Heat control module to an Automatic Temperature control unit, and I believe this sensor will make it work better. It is working OK now, but could work better in certain situations.
I was told by O'Reilly auto parts that this is the part my check engine light says to replace, but I can't find location. Found vent under dash right of steering column. Nothing is behind vented slats and opening doesn't line up with sensor. Any ideas?
