Cabin Air Temperature Sensor Location?
Old Apr 4, 2013 | 03:09 PM
  #31
AtlJeepsTer's Avatar
Originally Posted by rick77
Thanks. I ment the wire that hooks to the sensor that would go there.
year, Trim?
Old Apr 4, 2013 | 03:13 PM
  #32
rick77's Avatar
2012 sport.
Old Apr 4, 2013 | 03:15 PM
  #33
Attachment 442838Attachment 442839Not sure this site will let you blow it up to see the exact spot it would be if you had one....
If it's a Sport, X etc...you will not have a Harness, will have to add one
Old Apr 4, 2013 | 03:19 PM
  #34
2012 sport.
I just double checked again, if i put a Sahara , it lists all I need to know, diagrams, connectors etc....sun sensor wtc...
but when i enter a X or a Sport...the Cabin Air Sensor info is left out...
Old Apr 4, 2013 | 03:27 PM
  #35
rick77's Avatar
I have the connector for the sun sensor. Pretty much disassembled my dash but they're crafty hiding the harness behind that metal substructure in there.
Old Apr 4, 2013 | 03:28 PM
  #36
2012 sport.
Her is the Pinout and what the Connector looks like...they will not have a Harness..you will need to make one..
[h=2](IP) 4 WAY[/h][h=3]Mopar Package #: Not Available[/h][TABLE="class: zebrafied"]
[TR]
[TH="class: cav"]Cav[/TH]
[TH="class: circuit"]Circuit[/TH]
[TH="class: gauge"]Gauge[/TH]
[TH="class: color"]Color[/TH]
[TH="class: function"]Function[/TH]
[/TR]
[TR="class: odd"]
[TD="class: cav"]1[/TD]
[TD="class: circuit"]C36[/TD]
[TD="class: gauge"]22[/TD]
[TD="class: color"]LB/BR[/TD]
[TD="class: function"]BLEND DOOR FEEDBACK SIGNAL[/TD]
[/TR]
[TR]
[TD="class: cav"]2[/TD]
[TD="class: circuit"]C121[/TD]
[TD="class: color"]DB/DG[/TD]
[TD="class: function"]SENSOR GROUND[/TD]
[/TR]
[TR="class: odd"]
[TD="class: cav"]3[/TD]
[TD="class: circuit"]F921[/TD]
[TD="class: color"]PK/YL[/TD]
[TD="class: function"]FUSED RUN RELAY OUTPUT[/TD]
[/TR]
[TR]
[TD="class: cav"]4[/TD]
[TD="class: circuit"]Z903[/TD]
[TD="class: color"]BK[/TD]
[TD="class: function"]GROUND[/TD]
[/TR]
[/TABLE]
Old Apr 4, 2013 | 03:32 PM
  #37
The Sun sensor is in all Wranglers
Meaning the Wiring/Harness is, not the Actual Sensor is...
Old Apr 4, 2013 | 03:34 PM
  #38
Sun Sensor Info:
[h=2][/h][h=2]SENSOR-SUN - BLACK (IP) 4 WAY[/h][h=3]Mopar Package #: 68080566AA[/h][TABLE]
[TR]
[/TR]
[TR]
[TD="class: circuit"]L24[/TD]
[TD="class: color"]WT/VT[/TD]
[TD="class: function"]AUTO HEADLAMPS SIGNAL[/TD]
[/TR]
[TR]
[/TR]
[TR]
[TD="class: circuit"]G39[/TD]
[TD="class: color"]VT/LB[/TD]
[TD="class: function"]SUN SENSOR 1 SIGNAL[/TD]
[/TR]
[TR]
[TD="class: circuit"]G139[/TD]
[TD="class: color"]VT/OR[/TD]
[TD="class: function"]SUN SENSOR 2 SIGNAL[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
Old Apr 4, 2013 | 03:36 PM
  #39
You might be able to take that Mopar Number 68080566AA.. to buy the Repair harness (if the connectors are the same) and use it for the Temp sensor...
Old Apr 4, 2013 | 03:38 PM
  #40
Here is the Price:
[h=5]WIRING, 4 WAY[/h]
Product ID : 68080566AA
$29.60
$20.77
