Electronic stability control light comes on. Why?
Old Mar 4, 2013 | 06:38 PM
Momikey's Avatar
Default Electronic stability control light comes on. Why?
The other day I was just driving on the freeway doing about 70 and the ESC light came on. It stayed on until I started the Jeep the next day. It has done this twice now. Does anyone have any ideas why?
Old Mar 4, 2013 | 06:50 PM
Ryan0260's Avatar
Has your Jeep been recently lifted?
Old Mar 4, 2013 | 06:57 PM
Momikey's Avatar
No It's been lifted for about 8 month now. 3 1/2" lift with 35s on it.
Old Mar 5, 2013 | 03:52 AM
JK-Ford's Avatar
Is your steering wheel straight and true?
Old Mar 5, 2013 | 05:04 AM
Ryan0260's Avatar
This. Were you driving straight or cornering? Generally if your wheel isn't centered, you will have issues when cornering.
Old Mar 5, 2013 | 05:11 AM
JK-Ford's Avatar
IDK. If your steering wheel is slightly off, the logic thinks your in a turn. But if your actually going straight, then both wheels are moving at the same speed. Which would indicate a wheel slipping.
Old Mar 5, 2013 | 07:34 AM
Momikey's Avatar
I think my steering wheel is fine. I don't notice anything that whould make me think it's off. If it's off does it pull one way or the other how do I know?
What does that mean a wheel slipping? How do I make the wheel not slip?
Old Mar 5, 2013 | 08:53 AM
Ryan0260's Avatar
Traction control normally kicks in when the vehicle thinks it is slipping or in a rollover situation. A light turn shouldn't affect it. I had issues with mine at one point, but only during hard cornering, when some body roll was involved.
Old Mar 5, 2013 | 09:24 AM
Momikey's Avatar
It's strange. It just came on and stayed on. When I turn jeep off and then back on the light would still be on for a minute then shut off.
Old Mar 5, 2013 | 10:34 AM
JK-Ford's Avatar
When you lift your Jeep, it may be necessary to recenter your steering wheel ( is it slightly turned when going straight? ). The Jeep looks at the steering wheel position. And compares that to the different wheel / tire speeds. If the Jeep see's the wheel slightly turned. And both tires moving at the same speed, then it derives that one wheel must be slipping. Because in a normal turn, the outside wheel must be rolling faster than the inside wheel.
