ESP BAS warning Light
Old Jan 13, 2008 | 02:00 PM
  #51
NE Wrangling's Avatar
mine does the same as the first orignal post. It's good to know about the f7 fuse
Old Jan 8, 2010 | 02:33 PM
  #52
llyrad's Avatar
Originally Posted by LordEgg
A fix for this that came from My Girlfriend.
My girlfriend has a little mercedes kompressor that would do stuff similar to this and when my JK unlimited did it, she said go out (and this works) to the jeep, turn it on, turn wheels all the way left, then all the way right, then turn off. then turn on and drive. upon shifting to second it will go off. I swear to GOD it worked. I was floored.
Unbelievably, this actually worked for mine as well!!!!
Thanks
Old Mar 14, 2011 | 08:12 AM
  #53
jad99125's Avatar
I have had the same problem for awhile. Light is on but I am not getting any codes. I was told by the dealership that it is the right/rear speed sensor. Hope that helps
Old Mar 15, 2011 | 05:25 PM
  #54
r3vo3vom's Avatar
turn it on, turn wheels all the way left, then all the way right, then turn off. then turn on and drive. upon shifting to second it will go off. .
Light came on last night on the way home, tried exactly that and worked. lights off
Old Apr 9, 2011 | 04:51 PM
  #55
modestoperandi's Avatar
Same lights came on for me when driving home from the trail and I tried this. It works!
Old Nov 7, 2011 | 09:16 PM
  #56
dangoldminer's Avatar
Default that will trick just save me 100 dollar bill
I tried it and it worked the first time thanks
Old Nov 27, 2011 | 02:54 PM
  #57
Titaniumman's Avatar
THANK YOU A MILLION TIMES!! I wacked a rock with the right front tire yesterday and the esp/bas lights came on. Spent the afternoon checking the front for damage but found none. Checked the toe in and it was perfect. Recentered the wheel by adjusting the drag link and drove it but the lights stayed on. Used my Procal module to center the steering wheel but the lights still stayed on after another 10 mile test drive. Finally found your solution and tried it. Following the procedure and the lights went out after 1/4 mile drive. It worked for me, saved me a trip to the dealer and probably many $$. Thanks for the post.
Old Nov 27, 2011 | 03:55 PM
  #58
jeepsta's Avatar
Mine did this as well turning into a gas station took to dealer it came up with bad clock spring put new one in and now has been good for 2 months. He said this is in the steering colum and only held on by black electrical tape it can come loose and cause the steering to think its not straight.
Old Nov 30, 2011 | 04:28 PM
  #59
deleonl1's Avatar
This worked for me, too!!! I was glad to not have to make a trip to the dealer.
Old Sep 24, 2012 | 12:03 PM
  #60
puppetmaster's Avatar
This worked.... AMAZING!!! Thanks for the help!
