Footwell lighting
Old Nov 25, 2008 | 05:05 PM
  #31
tbfreebird's Avatar
Yup - we used this exact kit - h..p://www.ledunderbody.com/4pcexpandableblueledinteriorkit.aspx for under his dash. Worked well so we plan to do the same to my JK once the new ones arrive.
Old Nov 26, 2008 | 07:31 AM
  #32
trick50's Avatar
Originally Posted by Squad2man
Hey axsys where did you get your lights at? Also tbfreebird, where can I get this switch your talking about?
i think the switch that tbfreebird mentioned is called an LED Controller they sell them at tripleW.oznium.com
oznium is also a good source of LED lights. However if you want to get the LED strips which is what I used you can get them at Autozone, Pepboys, Strauss Auto or the cheapest is on Ebay.
Old Nov 27, 2008 | 01:53 PM
  #33
MYJEEP's Avatar
Any tips on how to make a good strong connection with the thin LED wire? Should I fold them over a couple times? Also, any pics of the ground?
Old Nov 27, 2008 | 02:37 PM
  #34
axsys's Avatar
my lights are actually not LEDs, but rather cold cathodes from a computer. you can get them from http://www.xoxide.com.
Old Nov 27, 2008 | 02:38 PM
  #35
axsys's Avatar
Originally Posted by TNJeepn
what a cool idea!! I am going to autozone tomorrow and see what they have in stock.
One quesion - the yellow and white wire thats on the passenger side. Is that the same yellow and white wire thats on the drivers? Im just trying to make sure they dim or if I need to connect them together.
Also in the back - what wire did you connect to back there?
i only touched the passenger side, so im not sure about that. but the same yellow and white wire on the passenger side runs up to the soundbar through the roll bar padding, so you can tap into it right there for the back.
Old Nov 27, 2008 | 04:52 PM
  #36
Squad2man's Avatar
Thanks I will be adding these in the very near future, with pic of course
Old Nov 28, 2008 | 06:56 PM
  #37
Saw 6" LED strips at Harbor Freight for 7 and change. Had red & blue. Similar to what I've seen at Autozone. Thanks for all the info.
Correction (R & B):
9" LED Red Strip Lamp
Waterproof design is suitable for exterior mounting.
Perfect for under carriage, dash or trunk highlighting and more
Includes mounting hardware and brackets
24 LED bulbs
12 volt DC
LED strip dimensions: 9-1/2" L x 0.282" W
Weight: 0.83 oz.
ITEM 98408
Old Dec 13, 2008 | 08:53 AM
  #38
BIGJ's Avatar
i really like those red lights under the foot wells, that looks really good
cant wait to do this mod also
Old Dec 13, 2008 | 10:51 AM
  #39
scotlandjk's Avatar
i did same mod red leds in the footwell and the blue ones for lighting up the gear shift area. i copid another forum member and used a 12ch rf controlled relay box. it switches on my leds and other acessories such as 12v outlet,CB radio,phone charger and anything else i want. its very useful as i only have one switch on the dash which controls the whole fuse box.
Old Dec 28, 2008 | 09:54 AM
  #40
ubergeekj's Avatar
This is a great write up! It works for what I need. Thanks!
