found a pass-thru on the firewall
i tried to follow this black hose for the firewall. i couldnt find a good spot. does anyone have a better picture that i could use to finally go thru my firewall. i have the 4dr version manual transmission. my dash is apart for my speakers and also my led lights. i just need a good spot to run some wires to my battery for my led, and other lights. help....
im not worthy if you help me
in this pic, the hole (with grommet and tube still in place) is located at the end of the red arrow.
i tied a loose knot in the wires about 6 inches from the end before feeding them through. it made them easier to see and gave me a spot to hook with a hanger, if i needed to do so. use a flashlight too.
I've got a new 2008 rubi ul. NO easy firewall access like the 2007. I pop the sides off the dash, poke through the insulation, and hit steel. I look from the engine side, and all steel, NO hole. Dammit. Luckily, I have an auto this time, and remembered something about a hole near the steering column. It was there, thank God. Not as easy to get wires to the passenger side behind the dash, but works. Anyway, I couldn't believe that the easy access was gone.
if your jeep has a hard top, the extra wiring goes through there... i was still able to get a coat hanger through the middle and using the duct tape method get a wire back through for my windshield mounted lights
Look where the green arrows point to. This is a hole filled with foam. There is the same hole on the passengers side too (no pic of other side as it's the same).
Just push something straight through these holes an pull the cables. They will show up under the cowl on the outside (yellow area on second pic).
Better pictures are here:
http://my.project-jk.com/showphoto.php?photo=18478
http://my.project-jk.com/showphoto.php?photo=18477
This is where I went through the firewall. It is on the driver's side of the vehicle just behind that piece of plastic that just pops off with your fingers or maybe a flat head screwdriver. No tools were needed when I took that piece off though, it just pops right off.
