Headlight relay buzzing
...overkill?It would actually be a bit more complicated because I'm thinking of placing a hidden on/on rocker switch to choose from the high beam or the accessory circuit for when I'm off roading
but that's a different story
So i just put in some HID's last night for the headlights... they are bright as hell but I have a huge problem..
1. So I turn them on low beams then turn right on and are bright as hell.
2. on my way to work driving down the road then the passenger side flickers and turn off and the driver side stays on. I am pissed so I turn on the brights and turn it off. they both turn back on I thought it was kinda weird.
3. driving for about 5 more minutes the driver side HID flickers and turns off and the passenger side stays on.
4. turn off the headlights completly turn it on they both turn back on.
5. this happend all the way to work. about 8 or 9 times.
6. FYI I drive a 2010 jeep wrangler sahara.. not sure if anybody else had these same issues. the lights are grounded to the battery...checked all connections and everything is realy tight...any suggestions would be a huge help.
See the thing is mine did some with a Relay for the Harness...the tech from the company that makes them said it is possibley getting to much vibration.. ha ha ha ha I laughed at him and told him you know i am driving a Jeep Wrangler right!!!
he was like ohhh well ummm... I would mount them better the best part is they wont take them back because they are used they are only a 5 hour flight from an ass kicking!!! LOL
Hey DSY!!
Thanks so much for that diagram!!! well do you think it will fix this issue i am having.
driving down the road everything is working great. go to turn on brights and the HID headlight turns off..and the Halogen bulb turns on and it is dark as hell....so then I turn then off and boom the HID goes back on...then went down a country road to test them out again and turned on the brights and the HID stayed on i was like wow that is weird now its working....so then i try to turn lights off and on the dash lights turn off but the lights would not turn off... I had to move it back and forth from on to off multiple times and then they would turn off....
Thanks
Jake.
Thanks
Jake.
I am confused about the diagram. It may be that I don't have my HID kit in yet with the harness. But does anyone have a clearer picture of the cap/diode trick on the actual wiring/relay?
And I have error cancellers coming in as well, so I hear that they will not work for the high beams. Is this correct? (DDMtuning).
see if you can find this relay it's solidstate and works with the low voltage that's at the jk's lights, mine has 9.10 v at the bulb, https://www.jk-forum.com/forums/show...66#post1528066 check this link.
