Help Wiring HID's using Factory Fog Wiring
Old 06-26-2010, 08:28 AM
AceDeuce's Avatar
Default Help Wiring HID's using Factory Fog Wiring
I recently installed an XRC front bumper and have 4" HID's to put on it. I would like to use the factory fog wiring & stalk switch. I tried wiring directly and got the flash 4 times and shut off business.
I just bought wire, 30 amp relay, etc. Here's my question:
Which factory fog wire do I use for the relay? There is a white/yellow on the right fog and a white/orange on the left one. Also, what do I do with the wire that I don't use?
Thanks.
Old 06-26-2010, 08:37 AM
GoodysGotaCuda's Avatar
I have 2- 35w HIDs hooked up to my factory fog light wiring with no additional relay. They spike at 14a and go down to about 7a. They don't pull much, if any over the stock fogs. I just stuck the pins that came with the hid kit into the stock fog connector and sealed it. Works just fine.
You need to power switch a relay if you want to use one. Use a multimeter or test light to see which fog light wire is hot when on to trigger the relay. The other, just tape up.
Old 06-26-2010, 09:53 AM
AceDeuce's Avatar
Thanks.
I tried the stock wiring without relay several times - never worked.
Just tested with relay and using white/orange wire. Works perfect.
Old 06-26-2010, 08:59 PM
pilot650's Avatar
do all the JKs have fog light wiring?
Old 07-03-2010, 08:02 PM
AZZKICKER's Avatar
Ace...where did you get your relay from and model #...looking to do same thing and was having the same flicker problem
Old 08-31-2010, 02:43 PM
AceDeuce's Avatar
Sorry - just saw this. Just a generic 30 amp relay from auto parts store.
Old 09-01-2010, 12:27 AM
I've got the XRC front bumper and got to looking at the location of the mounting holes for the lights and am wondering if the 4" HID will clear if a winch is installed? Looks like the back of the light is a tight fit.
Quick Reply: Help Wiring HID's using Factory Fog Wiring
