interior lighting help?
ok just like the title says. i have had a hard time with my interior lighting dimmer. it used to work occasionally but now i cant turn it off or all the way on with my interior dome lights. does anyone know if this would be covered under warentee or how much it would cost to be fixxed and how hard is it to do this?
Any ideas, or did you get a fix for this?
Any update on this... my dimmer switch does nothing. Used to work fine, then intermittent, now nothing. The turn signal works fine, the parking/fog/headlights part of the switch works fine, but when I roll the dimmer it doesn't dim anything and I can't twist it to turn on the dome lights. They only come on when I open the doors.
