IPF headlight problem!
Old Aug 7, 2014 | 11:10 AM
Jiblet's Avatar
Originally Posted by veney
The IPF bulbs we were amazing compared to stock. But as for any other electrical problems, there's none. And my jeep is a 2007. Just Confused at what I should do, I need a new connector now, but the bulb I put in now works but I'm worried it might melt more then cause something like a fire maybe. But all in all IPF definitely improved vision but right now I'm just scratching my head as to why this happened. Does any know what I should do in the mean time? Is there anything I can do?
You could bypass the OEM feed by using a custom harness. Costs a bit, might disable your DLRs.
Rallylights makes them. Or contact David Stern.
Or get a new set of connectors and replace the H4 connectors you are using.
Seems to be problems reported in this thread that just popped up again today.
https://www.jk-forum.com/forums/jk-e...-157548/page7/
Coincidently, the most recent poster is also in Canada. I'm wondering about the DLRs possibly causing the problem.
Old Aug 7, 2014 | 11:12 AM
Jiblet's Avatar
Also you could check out the automotive lighting subforum over on candlepowerforums.com
Lots of specific knowledge over there.
Old Aug 7, 2014 | 01:09 PM
tazzdogsocal's Avatar
I believe it got hot because -- bad connection plus heat from the bulb it self, just like jumper cables when they don't have a good connection they get hot,
Get new H4 connector's from a auto parts store and take it apart to solder the contention's ( not just crimped ).
If you can get at the connector's with out taking them apart that will work to .
Old Aug 7, 2014 | 05:43 PM
veney's Avatar
Tazzdogsocal - when I hardwired the headlights after they kept going out. I did solder + shirnk wrap + electrical tape. I noticed around where I soldered, (around the electrical tape) it's black a bit. I'm sure the hardwire + solder is OK. Something is getting over powered to much on the passenger headlight. Keep in mind
the driver headlight is perfectly fine.
Old Aug 7, 2014 | 07:27 PM
I ment not just your work but in the h4 conector it self, if its not making a solid conection to the bulb it will arc and that makes more heat.
Old Aug 7, 2014 | 08:01 PM
veney's Avatar
Woops read that wrong. Hopefully when quadratec messages me back they'll send new h4 connectors.. And bulbs... IF they message me back..
Old Feb 18, 2015 | 03:43 PM
rubiconranger1983's Avatar
Was this problem fixed? Mine do The exact same thing... Im going out to fix now. Hopefully i wont be shot putting a headlight over my parking garage tonight!
