JL Stealthbox
Old Dec 22, 2010 | 04:35 PM
  #71
fastrat350's Avatar
Originally Posted by potatar
I have a stealthbox in my 2010 Rubi and I have a few questions for you guys who may also have one.... Some songs sound great, but it doesn't seem to play rock too well. I'm running the JL 900/5 so I have 500w going to it. I'm not sure if it's just cuz I'm using the stock RER head unit and it's not giving the amp enough power, but I essentially have the gain up about 3/4 or more and the bass control knob is almost constantly all the way up to get good or any bass out of it.
Also, I know the JK's have a pretty good alternator, but when I turn mine up to 23/24 the lights are dimming.
Any thoughts?????
It's a lot to do with the factory head unit, factory units have a detuned equalizer, so even if you adjust it on the mygig the output curve is still tweaked in order to prevent damage to factory speakers. Which I can attest is true because when I ditched the mygig for the iPad I blew out a front speaker and the factory sub hits harder than when I had the mygig. I recommend adding a JL audio cleansweep cl441 it will correct the oem output frequency and correct to a truer flat frequency. It pretty much gives you aftermarket sound with a factory head unit. As for your lights dimming, do you still have the factory battery? That's the first thing to upgrade with an aftermarket sound system, don't bother installing a cap, they are useless.
Old Dec 27, 2010 | 12:34 PM
  #72
covalt's Avatar
I'm curious why you think capacitors are useless?
I received one from Crutchfield when I ordered my Stealthbox and HD900/5.
I had never used a cap before, but figured since they sent it, I'd hook it up and use it.
Also after talking to Crutchfield they really seemed to praise the capacitor, saying it'd make a significant difference when heavy bass is being output.
So I'm curious why you think they're a waste of time?
Old Dec 28, 2010 | 06:41 AM
  #73
blancolex300's Avatar
Capacitors do serve a purpose, however they are not a bandaid. If you got one for free, by all means use it. It can't hurt. If you have dimming issues, a better battery (Kinetik) will help. For the purpose of the cap, it will filter the power going to your amplifier, reducing any current ripple that may be present.
Old Mar 20, 2011 | 10:24 PM
  #74
cletusthepipeman's Avatar
Can I see some pics of the outside front and back. I would like to see how it mounts up. I'm sure some of us could make a box like that.
Old Apr 23, 2011 | 10:19 AM
  #75
eastcoasting32's Avatar
For all the 2 door owners, a 2dr StealthBox from JL comes out later this summer.
Old Apr 24, 2011 | 06:45 AM
  #76
Phishjeep's Avatar
I just built a new box to mount to the tailgate. I'd still ike to see what they do though.
Old Apr 24, 2011 | 10:29 AM
  #77
ToolManTimTaylor's Avatar
I have a JL in my ram and that thing SLAMS. I regularly impress many audiophiles with rediculous systems. Granted when I did build my system I used awesome componentry and dynomatted everything. JL makes awesome stuff.
